H&R Wheel Spacers
Old Oct 13, 2005 | 09:58 PM
2001SE's Avatar
H&R Wheel Spacers
There is the 15mm and the 20mm.
The 20mm is very tempting since the rear wheels are SO tucked in there. Really dont know why Nissan made it this way, it looks ridiclous.
I am just affraid its going to rub when I'll have some people sitting on the back especially if I am lowered too with the H&R springs.
Does anyone have pictures of 15mm or 20mm?
The price difference is like 6 dollars so thats not a problem.
Old Oct 14, 2005 | 12:08 AM
Talyan03's Avatar
if you have 225's roll your fander and you shoul dbe fine with 20mm
Old Oct 14, 2005 | 04:32 AM
Fezzik's Avatar
http://home.insightbb.com/~davidwhon...cer/spacer.htm
This is a writeup i did. At the end there are some comparison pics of stock and with the 20mm H&R spacers installed.
Old Oct 14, 2005 | 06:30 AM
MacAlert's Avatar
Good luck trying to find 20mm spacers. I ordered them almost 3 months ago and they still haven't come in.
Old Oct 14, 2005 | 06:34 AM
2001SE's Avatar
Thanks Fezzik for the picture/write-up
Man, these 20mm do a big difference in looks. How about performence in turns? any better? did the crappy radius of our maxima change a little? is it worse?
If I have 235/45 on a 17" stock rims with H&R/KYB GR-2. Can I put the 20mm and not rub? or I'll have to go with the 15mm so I wouldnt have to roll the fender?
How do you roll your fender and how about how much is it and where can I do it if I want to get it done?
Thanks a lot guys
Sorry for all the questions
Old Oct 14, 2005 | 06:36 AM
MacAlert's Avatar
You should be fine with the 20mm spacers.
Old Oct 14, 2005 | 07:47 AM
2001SE's Avatar
yeah, I looked at the car today and it looked fine to stick them out 2 cm.
Any other people who dont think differently?
Is there a cheaper place to get them online that someone knows?
Old Oct 14, 2005 | 08:17 AM
ColdSHO's Avatar
i just finally got my 12.7mm's in and they look awesome compared to my 8mm's im dropped on jic's rather low, so i was kind of afraid 20mm's wouldnt clear right, they loo like thtey would, but then my fronts would seem to set in".
also the nismo studs are long enough, i could prob run a 30mm and still have treads
Old Oct 14, 2005 | 08:51 AM
2001SE's Avatar
so the 15mm would probably be perfect with the drop and the 235/45
I think it will match perfectly with the fronts if I go with the 15mm
Old Oct 14, 2005 | 04:25 PM
Fezzik's Avatar
I dont know. For me i did a 1.75" drop in the rear and i still think it needs a little more, but the fronts do need a 5 or 10mm spacer to look better.
Old Oct 14, 2005 | 06:13 PM
OOmaxSE's Avatar
20mm for the rear
10mm for the fronts
those measurements above should be ideal for wheels to sit flush to the fender without rubbing.
someone actually said that they could prolly squeeze another 5mm on their 20mm spacer for the rear. so i don't think you'll rub.
Old Oct 15, 2005 | 07:29 AM
sublimer's Avatar
i got 20mm in the rear with 225/50 tires, lowered on H-techs. No rubbing whatsoever. I coulda probably gone another 5 mm too. Check my cardomain for pics.
Old Oct 15, 2005 | 08:49 AM
NISMAX03's Avatar
I had 20mm H&R spacers on the rears with 235/45/17 tires and the OEM TE rims (45 offset). I also had Maxspeed springs and had no problems with rubbing even with people sitting in the back seats. I also had 15mm H&R spacers up front with the same setup and had no problems.
Old Oct 15, 2005 | 10:25 AM
ChromeSE5's Avatar
i have 33mm spacers in the back and it causes rubbing on OEM rims. This is completely flush with the rear fenders.
Old Oct 16, 2005 | 04:15 PM
JoeJoe's Avatar
Re:
I've got 15mm in the front and 20mm in back lowered with Tein S and have no problems. Pics on my site.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
