Heated Seats
Heated Seats
since I hear that this winter coming will be the winters of all so far winters.... I am looking to implement heated seats... now my question is
1 - can it be done?
2 - I noticed that my fuse box has this slot with a fuse already there, so does this mean that my car is prewired to the seats?
3 - where can I purchase an aftermarket set?
4 - where can I purchase the switches and wiring harness?
any information that is given towards my questions and questions that I did not ask is appreciated.
Thanks fellas...
1 - can it be done?
Thanks fellas...
http://cgi.ebay.com/ebaymotors/Seat-...05226758QQrdZ1
those need to be put under the actual material (either leather or cloth) and i believe a button is included..
http://cgi.ebay.com/ebaymotors/45-Bl...spagenameZWDVW
that is ontop of the seat..and is supposed to be plugged into the cigarette lighter...im pretty sure you can take off the material on your seat..and put this type of pad uderneath..also you can take apart the cigarette lighter adapter and wire it to a swtich..and wires the switch to the back of the cigarette lighter (to hide all the wires)
side question: I currently have heated seats and have left them on accidently several times and came down in the morning and found a dead battery. Is there a way to wire the seats to only function when the car is on?
Originally Posted by Dan
use a relay to disconnect the power to the heat seats when the ignition is off.
Where do I tap in to get the power? How many volts are needed? would this relay work? http://www.radioshack.com/product.as...5Fid=275%2D248
tarun900
19
Dec 20, 2021 06:57 PM
