Still no proper headlight housings for HID's?
Simple question, other then self mod headlamps are there any housings out there designed for HID's for a 96 Max yet? I love HID's the performance and look of them but would rather try and stay legit if I could.
the h4 cefiro housing + HID spread the light out a lot better than stock but i wasnt satisfied with the amount of output onto the road. i stayed with the setup anyways.. youre only best bet right now is to do the projector retrofit + HID if you want a strong focus of light. i dont believe there are any aftermarket HID housings for the maxima that are a direct bolt-in.
The lighting aftermarket is a hater of 4th gen maxs. The performance of a just a plug and play kit IMO is better than stock but not worth the money when you can spend almost the same amount and get twice as much lighting. For a 95-96 I would say try to go with 97-99 housings because the fluted lens on 95-96 robs light, and then probably a 9007 conversion, then just save up for a proper retrofit.
There is such thing as a reflector retrofit, as the name implies you cut out the stock reflector and retrofit one from a car that runs a d2r set up like an IS300, 5th gen max, etc . I've never seen it done on a 4th gen though. It would be cheaper than projecters, legal, and definitely put out more light than stock.
I had looked initially at the A6 housing (too big) and the TL housing (weird shape).
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
