Let this be a lesson, dont buy cheap tires. (Long /w pics)
Im leaving the body shop around 7pm tonight, just had my trunk and spoiler redone and a short throw shifter installed. They didnt paint the whole car since the trunk and spoiler had already good paint on it, but i noticed so i bought it back to them. So back to the story, im leaving the shop, following my cousins 4 runner. Two blocks away from the shop the light turns red so he slows down and I attempt to. Im in third gear and slowly easing the brakes in, i notice that im not slowing down so i paniced and floored the brakes, but the car is still moving. My last thought was to slam on the clutch to disengage the engine but it was too little too late, bam straight into my cousins car. We pull over and observe the damage, first thought that occured to me was wtf did these guys do to my brakes. I call them up and asked them, they showed up within minutes. I took my cousins car back to the shop while the mechanic drove mine, for safety reasons. After i arrived at the shop, the mechanic told me right away that my tires were ****. I said no way, those things are practically brand new, they have about 90% tread left on it. So he said ill show you for myself, we went down the block at around 25mph, 3rd gear as i was. He slammed on the brakes and the wheels locked but the car skid about 30 ft. Lesson learned. Luckly my cousins 4runner wasnt even scratched, i hit his tow bar thing and it left this on my bumper. Dont skimp out on tires!!!!
ouchies...learnt my lesson LAST friday...goin down a backstreet , starting sliding sideways...nearly hit a truck O_o...now i need a " Handbrake Boot " as the mechanic says..$45 :-\....Lesson for me? Tires before Head Unit..
Originally Posted by 99grnmaxgxe
What kind of tires did you have? (brand/size)
Originally Posted by white97gxe
.... we went down the block at around 25mph, 3rd gear as i was. He slammed on the brakes and the wheels locked but the car skid about 30 ft.
From: a charming town in Connecticut first settled in the 1600s
it took a helluva lot of googling, but i found the website! Apparently Fate O is made in Argentina. http://www.fate.com.ar/esp/frame.asp
I didnt purchase the tires, i would never purchase a brand that i never heard of. The tires came with the car. Yes i do clutch in when i stop at a red light but i usually slow down, clutch, shift to neutral, then stop completely. Thats why clutching in was my last thought.
that sucks dude. my tires are just as bad, if its anything near wet, they just lock up and lose all traction. ive almost slid off the road twice, one out of stupidity, the other out of just plain crappy tires. they also burnout very nicely, like AWESOME burnouts, but they do it on like a 2500 neutral drop. not good. (if you cant tell im trying to get them bald enough where my dad feels new rims/tires are necessary!)
That reminds me, when i first purchase the car, the owner was raving about his "new tires". So i looked up the brand on google but i coudlnt find a website. What i did find was comments and reviews on forums and one of them said "Fate-O tires are great, just dont plan on driving if i rained in the past 3 months."
Originally Posted by chenzarino
Clutching in decreases traction, you should have downshifted. Why didn't your brakes work? Or were you sliding and didnt realize it?
It seems there is a lot of misinformation here.
Braking on wet surfaces is a function of two things:
1) a functioning ABS system (for control, not so much for braking distance)
2) traction
Traction is a combination of two things:
a) contact patch (proper tire inflation and hydroplaning)
b) rubber.
Brakes are capable of stopping the car in the minimum possible distance if they can lock the wheels. Period. Rotors, calipers, engine braking, suspension, etc are irrelevant in emergency straight-line braking.
Worn tires are usually worse at a) and b) because they are prone to hydroplaning at lower speed due to shallower tread, and because the rubber usually hardens as it ages or get harder the deeper you wear into the tread. Cheap tires do both, earlier and to a worse degree. As well, more traction = shorter life. These are two reasons to never wait until a tire is all the way down to minimum tread depth before replacing them.
Buy some decent tires. Getting your car repainted without knowing exactly how good the rubber on your tires is, is simply idiotic. IMO, $600 is as cheap as tires should be on this car. Anything less is compromising it's so-called 'sports car' characteristics (and I'll debate that, FWIW).
Dave
had a bad experiance with this once befor on my old max.. now i do not put anything but potenzas on my car as i know the brand and i have done alot of research.. true i could get better but there is no way i will get worse.. i want all weather performance and traction and potenzas are rated high according to tire racks customer guides and ratings so i go with those.. spend the money if you want to keep your car and your life... i think tires are more imortant than any other thing i put on the car other than brakes...
lesson learned for you i guess.. sorry for your bumper tho!!
Two things.
1. There isn't any tread in the middle part of the tires from the pictures you show.
2. Your brakes are not working. There wouldn't be that much rust on your rotors if it were.
3. You probably need a master cylinder.
4. You bought the car and the tires. Check before you buy.
5. There is no way those Fate-O tires could be crap if they are new and have a DOT rating on it.
6. You can get inexpensive tires even if they are Fate-O's and still be nearly as good as the high priced Pirrellis or whatever. I am running Hankook and Cooper Cobras. Doing fine.
besides that, do you seriously believe that cheap tires perform as well as expensive, high-performance ones? are you high? with tires, you USUALLY get what you pay for. yes, there are tires that are cheap AND perform well, but $20 walmart tires or whatever DON'T.
Ok then, why doesn't he have any brake dust on his rims?
His rims are so clean...even on the inside looks like you could serve dinner on them.
I used to buy my tires from Wal-Mart. What are you trying to say?
I don't even know if the DOT would allow cheap tires on the road, but I heard you could get some retreads if you really tried.
Read what you just posted please, and I quote "Rotors, calipers, engine braking, suspension, etc are irrelevant in emergency straight-line braking". So what pray tell stops your car? Do you have a hole in the floor and put your feet down? Because i'm dying to know how you stop a car without any of these things being relevant.
his rims are painted gunmetal, just like mine. i can't see brake dust on my rims, EVER, and that's why you can't see it on his.
and i'm trying to say that if you spend any less than $200 on four BRAND NEW tires, you shouldn't expect them to reliably perform in any kind of stressful conditions: rain, high speeds, quick stops, or whatever.
the dot probably wouldn't allow tires that were just straight up unsafe in ANY conditions, i.e., they are prone to blowouts at low speeds, their tread pattern is such that they have no wet traction, etc. that's not the case with these tires; if you want to drive around at 20 mph, only in reasonably dry weather, leaving a lot of extra space between you and the car in front of you... they're fine, but for normal or slightly aggressive driving, they're subpar, borderline unsafe, or worse.
i would know: when i bought my car, it had those kind of ****ty tires on it, and it was honestly kind of scary to drive. it always took longer than it felt like it should to stop, and i could barely drive in any kind of rain. luckily, within two weeks i replaced them with the yokohamas i have now (which weren't expensive by any means, about $100 each) and the car felt a lot better.
EDIT: i'm not saying his brakes are necessarily in great shape. but if there's anything wrong with them, you can't tell from the pictures he posted.
A couple things should be said. First of all to the thing about no brake dust. It is possible to have a car without dust ive had my brakes on for 5 months now still no dust. They are aftermarket but still is possible. Other thing how much rubber that is on the road is the biggest thing when it comes to braking. When its wet and u lock up its like driving on ice. Thats why its very important if you dont have abs to learn how to do emergency braking without locking up. It all comes down to driver experience and knowing how to use what you got. If you dont know how to use it properly it doesnt matter how expensive the stuff is that is on your car.
So tell me Einstein, how do you think a car slides on a wet surface? When the wheels lock up.
If you couldn't stop in time, either something compromised the contact patch or the tires didn't have enough grip. And in both situations, you were following too close (but maybe didn't know it until it was too late).
Got it Einstein?
Dave
Two things.
Cheap tires: bad
Overinflation (narrower contact patch): bad +1
Heavy tread wear: bad + 2
Wearing down to the harder rubber below the tread: bad +3
Correct inflation pressure for a Maxima is 30psi, and usually +2 or +3psi in the front wheels. Never use the 'max pressure' labeled on the tire. 35psi is fine for mostly highway driving, but above 40 will distort the tire and cause problems.
There is no evidence in those pics that the brakes are malfunctioning.
Dave
Originally Posted by lanky2882
maximum stopping power isnt when the wheels locks up it is right before they lock up. ABS isnt only affective for better control its also improved stopping for a less experienced driver.
I do forget at times that ABS is not common on 4th gen Maximas.
Dave, he doesn't even have brake dust on his calipers. My car has been sitting for 12 hours and I drove through the rain and I don't have rust spots like that. It looks to be about three days at least worth of rust.
I run 35 psi. You run 30 and the next day your tire will be 29 psi after 100 miles of driving and slight weather temperature changes. Best to start at 35 psi unless you are driving on sand, snow or rain then drop down to 32. 30 is probably going to wear out your tire very quick and give you around 24 mpg gas mileage compared to 28 or better.
The rust spots don't always appear, since even on a rainy day, they are quite warm when you stop driving and dry themselves. Unless it's a breezy day, they are sheltered enough to remain dry. I usually notice the rust spots the next morning after washing the car.
As for the brake dust - it depends on what kind of pads you have how quickly dust will accumulate. Plus, it looks like things have been recently cleaned. I can't tell anyway - the pics aren't good enough, and it's nearly impossible to see brake dust on a cast iron caliper, even in person.
In any case, the pictures don't indicate the brakes are having any problems.
For tire pressures, I think 25-40psi are all good working pressures for a Maxima. 40psi may distort a cheaper/lower speed rated tire more than a better tire - such that this tire ballooned at 40psi when the car wasn't heavily loaded.
When I bought my RX-7, the tread on my tires looked fine - when it got to the tire shop for inspection the next day, we found the very inside edge was worn to the cord. (I hadn't taken the wheels off yet - so that wasn't visible). The rest of the tire had 80% tread. Turns out the previous owner hadn't done a thing with the alignment or tires in the 5k miles he owned it, and the guy before that was a national class autocrosser. So his alignment settings and tire choice were, uh, aggressive. Tire wear has a way of sneaking up on you like that.
Dave
Dave
Id like to know too
