Quick help needed in cd player installation
Old Oct 22, 2005 | 08:55 PM
Brendan's Avatar
Hey guys, I am trying to put my cd player into my 92 se. I'd rather just splice the wires and do it myself rather than bring it to a place, both because of cost and i like to just do it myself anywho... Now I'm havin a hard time with the wiring and color matchup from the harness i have and whats in the max. Anyone know any website i can access that will tell me what colors are what?
Old Oct 22, 2005 | 09:44 PM
Phoenix's Avatar
Lives in a Maxima
you didn't already cut the connectors off did you?
If you didn't, go pay the $15 for the little harness that goes from Nissan female connectors to bare wire and attach that with some crimps or solder or both to the stereo harness.
The colors are pretty much the same on the two and easy enough to figure out... if the harness doesn't come with a diagram
Old Oct 22, 2005 | 09:52 PM
Brendan's Avatar
nah i wouldn't cut if i didn't know what went where, thanks for the info man
Old Oct 22, 2005 | 09:53 PM
Phoenix's Avatar
Lives in a Maxima
Very welcome...
You can walk up to any of those places that charge you $70 to install it and ask them for a harness for a 92 Maxima and they'll know what you need. Should be $10-15.
Old Oct 22, 2005 | 10:33 PM
Brendan's Avatar
Yeah I know what you mean, in my jeep i jsut cut the wires and spliced them all myself without buying anything so wasn't sure if i could do that or needed harness, thanks again.......
Old Oct 22, 2005 | 10:45 PM
Cliff Clavin's Avatar
Way out West
Buying a harness is way easier now and down the road.
Since you have a 92 SE, I assume you have Bose. Please take note that Bose is totally different from normal aftermarket car audio. Each speaker has it's own amplifier and the signal levels are different than normal. If you plan on keeping the stock speakers (and their built-in amps) you should look into getting a line level adapter. I had one from a company called Peripheral and it worked pretty good. Eventually, all of the speakers and/or amps got fried.
I eventually took out everything in my car that says "Bose" except the speaker grills and started from scratch. Most of the members on this board that has an aftermarket head unit also has aftermarket speakers.
Old Oct 23, 2005 | 01:26 PM
Brendan's Avatar
wait so i can't just buy that 20 dollar harness since i have the bose can i? I'm gonna need a special one right?
Old Oct 23, 2005 | 01:27 PM
internetautomar's Avatar
mod or sell?
it's more complex than just harnesses on the blose
Old Oct 23, 2005 | 04:25 PM
ozzombie13's Avatar
I will eat your children
unless you want to replace all the speakers in the car you need to do a littje more heres an example of someting you could use. i would personally replace all the speakers, as i did.
Installation Details for your 1992 Maxima
» Because your vehicle is factory-equipped with a special sound system, Crutchfield recommends that you purchase an adapter. This adapter eliminates the need for extensive and time-consuming re-wiring when you install your new receiver. In some cases, not using an adapter will make it necessary to replace the entire factory sound system, including the speakers.
OEM Amplifier Integration v.4 $39.99
Old Oct 23, 2005 | 06:04 PM
cwd14's Avatar
I put in a new head unit and my sound system is going down hill, I will probably need to replace my speakers soon also.
Old Oct 24, 2005 | 12:38 AM
Loco7's Avatar
Keep mind what is your final goel for your stereo. If you plan on running subs and the works just get a amp for your mids and run all new lines to some new speakers. using the built in crossover on the amp adjust the frequency on the amp with your deck treble and bass at 0. It's better to let your mids play that way they were intended (little to no bass) so you don't cause as much "wear and tear" on them plus cut down on distortion and your subs will do what they are suppose to do play bass. It's sound like a lot of trouble but if you liek to listen to music without one range drowning another it's worth it!!
I have 1 amp going to my mids and another for my subs. The the diffrence in the Mids and high is great, add in bass and the stereo gives me a head ache and a ear ache after awhile. Now that MUSIC!!!
But for your origanal question BY the WIRING HARNESS ADAPTER!!! Heck you can even find them at Walmart. Make sure you get a antenna adapter too!! unless you never listen to radio. But some after market decks require it for a grounding system even though it already has a ground.
I know that all wasn't what you wanted to know but... hay i love loud stereos
Old Oct 26, 2005 | 06:54 PM
theycallmekj's Avatar
im looking to get a cd player for my 92 maxima...where can i get one? do i need anything to install it? what do i do to install it?
Old Oct 26, 2005 | 11:42 PM
Loco7's Avatar
you haven't read any of this thread have you?
Old Oct 27, 2005 | 06:13 AM
xbubbax's Avatar
dood go get the wire harness and the dash kit and take a good 2 hours of your day and put it in correctly.....its all color coordinated unless your colorblind then your screwed....i just did mine it my 93 and it took me literally 1 hour.....the lingest was hooking the wireharness to the radio....each wire. but its well worth saving the 100 to get it installed....and they can **** you on a price the say 50 labor and it took them 4 hours......they must have been working while eating or somthing. is shouldnt take longer than 2 hours max
Old Oct 27, 2005 | 06:18 AM
xbubbax's Avatar
woah!!
wow....read 1st then post...
Old Oct 27, 2005 | 06:30 AM
disgruntled's Avatar
^^^^^ lol, and you wonder why so many people can't do some very basic thing, they never read!
on a serious note, yes, do as everyone have said, buy a harness adapter, and an antennae adapter
those two things with a roll of electrical tape or heat shrink tubing + phillips screw driver + wire stripper (scissors or razor blade will do as well) = 50 bucks richer when compared to the "professional" installation.
Old Oct 27, 2005 | 06:52 AM
xbubbax's Avatar
do you still ahve the factory speakers/ bose sustem in your car.....if you do than yea....that even before a head unit.....why put a head unit in if your speakers will not handle it?
id say replace the speakers ASAP and get your headunit running up to par.
Old Oct 28, 2005 | 04:08 PM
Brendan's Avatar
it's not more complicated than that, a harness works fine.......
Old Oct 28, 2005 | 07:51 PM
mattcomet82's Avatar
woah. an aftermarket head unit will take lots of work to mate with a bose system. hooking up a powered h.u. to powered (active)speakers will blow 'em in no time. another option you have is going into the front speaker pods and bypassing the amp, just cut it out of the loop. you can do this with the rears to. this will only last you so long though, since bose speakers run on different ohm ratings than your h.u. your best bet is to replace the speakers with new ones, so you no you can't blow **** up. james92se sells speaker pods that modifies front holes in doors to fit 6.5" drivers. and a factory service manual will help you out with all the wire color codes you need.
yes, it is more complicated than just wiring a new harness to the wiring behind the dash. then it will be a matter of time before your speakers go up in flames.
Old Oct 29, 2005 | 01:26 PM
Brendan's Avatar
actually i had a harness run in my other maxima with the bose for about 8 months and teh guy before me for over a year and nothing fried........
Old Oct 29, 2005 | 05:05 PM
mod or sell?
the ability to ony use a harness varies by the head unit.
some head units are able to work with the amps, others will get fried.
it also depends on if you bypass the amps.
there are lots of variables
Old Oct 30, 2005 | 10:29 PM
Brendan's Avatar
thanks for the input, by the way its a kenwood deck that has yet to have any problems and im pretty sure will not.......
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
