Ran tire down to 8psi! Is tire damaged? How to fix?
Old Oct 24, 2005 | 08:34 AM
BG's Avatar
BG
I usually keep a pretty regular check on my tire pressures for safety. I'd hate to go do some playful driving on dangerously low tire pressure.
I had new tires installed about 1½ mouths ago. I check them about 2 weeks ago and the drivers rear tire was down to 18psi. I usually keep them at 30.
Well I was pumping gas today and noticed that the tire looked very low. It was at 8psi.
Obviously I instantly pumped it back to 30.
Do you think I incurred any long term damage to the tire?
Also, what is a good way to get rid of a slow leak like this? I guess I could try the Fix-A-Flat Foam, but does that work on slow leaks. Also will it kind of weigh my tired down?
Or should I just take it to a tire shop and have them look at it?
Thanks,
Brandon
Old Oct 24, 2005 | 09:01 AM
Bobo's Avatar
What part of go to a tire shop do you not understand? You should also be running your tires at more than 30psi. My car calls for 33F/32R and I'm currently running the tires at 35F/34R.
Talk to the tire shop about that as well!
Old Oct 24, 2005 | 04:19 PM
TurTLe*'s Avatar
A 4th gen i think the suggested is 32psi all around or something like that. I normally just do 35 all around reguardless of what the specs are. My left rear looses psi every now and then but thats because i have a nail actually in the tire. And it would be more dangerous to pull it out then let it be. As of now i loose about 2 psi a week.
Old Oct 25, 2005 | 08:58 AM
Ammi's Avatar
350 Detroit Muscle
take it to a shop
Old Oct 25, 2005 | 09:56 AM
Dasyce's Avatar
you had new tires install a month ago, and they leak that bad?
Sounds like a very poor install job. you shouldnt be losing air.
Go back to the place that did the install and complain.
Old Oct 25, 2005 | 10:34 AM
BG's Avatar
BG
Turns out I had a small nail towards the inside of the tire. I had this plugged.
But it teaches a good lesson. Always do a hand check of your tires before doing any playing around.
Just a few days ago my tires where at good pressure and I did a couple 120 runs in my car. Now that I think of it that nail was probably in the tires then and just hadn't allowed much air to escape yet. However, that could have been a major problem at those speeds with a nail in the tires. Thank god nothing went wrong. Just a warning to others... do more than just the eye check.
ballerchris510
Sep 10, 2015 09:35 PM
nbstriker10
Sep 4, 2015 04:26 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
