Finally installed High Flow Fuel Pump
The other day I was bored so I decided to install the high flow fuel pump. It took about 1 hour for the install. One thing I've noticed after I started the car was that the aftermarket pump was loud. It makes a buzzing sound more noticeable from the outside of the car. To those that have done this upgrade, is this normal or do I have a bad pump?
The unit I have is from Walbro. Thanks for any input.
Originally posted by SmoothMax
So what are the benefits of up grading the fuel pump? I know it's preffered with nitrous but will it effect the performance of a NA car?
don't think you'll gain anything from that. you'll just run rich if you run an upgraded fuel pump with the stock regulator.
I had one in my last car, they are quite loud, the cheap one's are more of a pulsating noise, the dearer ones make more of a whining noise. Have you installed yours in or out of your car ? You can try using some rubber grommets to build up the mounts. i did this and reduced the noise considerably, though i had the ball bearing pulse noise, hope i was of some help.
You should hear the Holley one I have in my boat on a 390 Ford.You should be glad they dont sound like that I run a seperate switch just for the fuel pump I turn it on before I start it.eeeeeeeeeeeeee then you hear zzzzzwwwwwuuuuuuuummmmbbbummmbbbmmmmmmbubmbmmbubum bmbu!!!ha!ha! The feeling of 575HP behind the pedal is great.
Re: Model Number
Originally posted by RKS
Can you tell me what model number you are using and where ya got it from? Thanks.
a few more questions...
Originally posted by BottleFedMax
It is a HIGH PRESSURE Walbro GSS340 255lph and I purchased it from Muscle Motors Performance # (818)888-7778 I paid $139.
Can you answer a few more questions?
Did it just swap the place of the oem or is there additional items needed?
I guess you HAVE to run a FP regulator or do you constantly run rich or does the ECU control fuel flow?
Hey how about danger of ignition at the CAT? -->
running to rich is actually dangerous if you have an aftermarket Y pipe and your car is not tunned up.
The precats are removed (of course) and the exhaust goes directly to the main CAT which is very hot. Running rich with not good spark plugs or if the spark is not set to top dead center, some of the fuel may leave the chamber unburned and go directly to the Main cat and ignite. The CAT will burn, the O2 sensors will be affected.
Just a "watch out" for you guys,
Peace
Peace
Well, with the addition of the new fuel pump, you will need a Fuel Pressure Regulator so that eliminates the problem of running rich. It is fully adjustable but does cost more $$$; Also with the addition of the ECU chaning all the time.
With the NOS kit, there is a Fuel Pressure Safety Switch which is set for a range in psi that is safe for using NOS so it wont be running rich there either.
I guess this is a reason why people keep blowing the blocks out of their cats or clogging it up.
With the NOS kit, there is a Fuel Pressure Safety Switch which is set for a range in psi that is safe for using NOS so it wont be running rich there either. I guess this is a reason why people keep blowing the blocks out of their cats or clogging it up.
Re: a few more questions...
Thanks for the info.
Dman1989
Aug 27, 2015 09:10 AM
homewrecker
Aug 24, 2015 08:56 PM
Team STILLEN
Aug 10, 2015 04:29 PM
