rear strut cartridge
i went to replace my rear strut cartridges today and the KYB cartridges stick out past the end of the tube by about a quarter inch. as such, the threaded cap that secures the cartridge in the tube doesn't go on all the way and has about a quarter inch of thread showing.
i got KYB cartridges # 365079 and i have double checked the number and that is what i am supposed to have.
this is not giving me warm fuzzies. is this normal?
not only with KYB cartridges, same thing happened when I raplaced my rear cartridge with a monroe sensatrac one, the only difference is that that end is only sticking up by about 1/8 of an inch or less, but after the circle metal washer is put on, the end cap did not go in all the way either, but I made sure it's as tight as I could possibly get it, and things seems to be ok. This was about 3k miles ago.
1. Shave the bottom thingie, that is welded to the bottom of the KYB with an angle grinder or...
2. Use a KYB cap (I was told it existed, but never got a hold of it)
I simply live with the cap not all the way in since I replaced my struts.
Originally Posted by Wiking
Were the old ones original? If not, there might be a 'filler' in the bottom for stanza or whatever u got there...
Originally Posted by Mizeree_X
I know my Tokicos came with new gland nuts and they didn't thread in all the way either.....
Mizeree...Are you currrently running tokico's on your car? What springs are you using?..
Tokicos and Eibachs. I have B&G springs waiting to be installed, but I probly won't do it till spring now.
Thanks guys.
Tarzan - my kyb cartridges came with a gland nut. the original nissan nut is not the right size for the kyb.
Did you end up figuring everything out?
as long as the gland nut gets like 5 threads inyou should be OK
just got your message onthe phone.
as long as the gland nut gets like 5 threads in you should be OK
i only have the rears replaced but i drove the car about 15 miles to find a rough road and the car was a heck of a lot more stable on it. i'm going to install the front struts after lunch today.
Are you out celebrating the White Sox? My wife is.
i think about half of the gland nut threads go into the tube. the others replying to my thread have all had the same experience and with other brands as well.
I received only the cartriges, no gland nuts. Internetautomart told me to contact KYB and I did, but they probably played a dummy and replied, that the Maxima cartriges did not require glund nuts. There was no reply to my second email where I asked them if we were talking about different things etc. Anyway, I am not going to redo the job, the original nuts seemed like they sealed the struts pretty firmly.
Replaced my two weeks ago with KYB bought from internetautomar. The thread also still stick out about 1/4 inch when I tight it all the way in (using the gland nuts came in the package). I guess it's normal then.
Good to see another maxima in Plano.
the kyb's should have come with a brand new nut. mine did. they went together perfectly. not sure how bad it is to try and get those with out the struts, just yell at kyb for a while unless your happy with it
i think tarzan shaved the bottom spacer so he could use the original nissan gland nut. i had tried to get info from kyb's web site and i had better luck talking to myself.
I just put KYB's and B+G springs on my max recently and they were the same way. I just cranked them down with some locktite and everything seems great.
Yup me too on the KYB's. They will only thread in as far as you mentioned and they will be fine that way. If I'm not mistaken, somewhere in the KYB install notes it even mentions this.
after about 2 weeks of having the kyb's, i like them. there is one section of road that i drive on that is pretty bad and now I feel comfortable doing 60 mph on it where i had to keep it down to 40 before and slow down even more to avoid bottoming out at a few places.
dvcamp
Sep 18, 2015 10:17 AM
ef9
Sep 5, 2015 11:18 PM
