Sputtering and vibrations
Old Oct 31, 2005 | 09:24 AM
mukundan's Avatar
Hi, My Maxima '91 with 92K miles started developing occasional sputtering and low vibration. The symptoms have increased since I observed this first in July. After my 90K miles service I thought the symptoms disappeared completely but it is still there!
Also, the gas mileage has been deteriorating -- 12 gallons fetching only 190 miles (citi) or so. But in highway it gives me 290 miles.
Can anyone suggest the possible cause of this? Please let me know if you need additional information. Appreciate your input before I take it for servicing!!
Old Oct 31, 2005 | 09:52 AM
Wiking's Avatar
Originally Posted by mukundan
...92K miles started developing occasional sputtering ...
Seems like mymax 2½yrs ago as I got it... read the things I found, corrected and documented here: http://www.cardomain.com/ride/748507/1
Old Oct 31, 2005 | 10:25 AM
mukundan's Avatar
Thanks Wiking for the fast response!
Great site that you forwarded! Can you please direct me to the specific page?
Old Oct 31, 2005 | 10:35 AM
Wiking's Avatar
Typical first problem is plugs, cap, wiring. My second was TPS (cold), then oxidized connectors & groundings like cam pos sensor gnd in the distributor, pages: 6,10,12,14.
Old Nov 2, 2005 | 07:34 AM
mukundan's Avatar
Hi,
Today, I gave my car for servicing and they diagnozed that my #3 and #5 injectors are not showing any voltage at all :-(
But when I looked at the ECU codes all I saw was 5 red and 5 greens. Is it because my Maxima is 1991 year?
And does this justify the low mileage I have been experiencing?
Please post your comments....Thanks in advance!
Old Nov 2, 2005 | 08:54 AM
bhunter's Avatar
Wiking needs to get a VE so we all can get the full benefit of his ability.
Old Nov 2, 2005 | 09:26 AM
mukundan's Avatar
My Maxima is 91 GXE. Any help?
I see that Wiking is off today...
Old Nov 2, 2005 | 09:57 AM
Wiking's Avatar
Smbdy get the hat, start passing along. Send it to me after VE-mon€u is pouring over from tHat Hat.
Camera batteries have been loaded already for writing new VE FSM... Maybe for VQ also?
mukundan:
"they diagnozed that my #3 and #5 injectors are not showing any voltage at all :-("
- they desperately need $$$ to pay their rent?
- take screwdriver, place it on each injector, ear on handle. Listen. If all injectors make the same noise, they do get their voltage, wirings about ok, they do work mechanically. (still no warranty that they do work properly)
- However, the day comes to swap them.
- Bad KS and/or O2 will cause bad mileage. Dragging brakes...?
Our BDII ECU is reliable: It will show error codes ONLY in the junkyard... Take one injector wire out, view for ECU: is it still happy55??
Old Nov 2, 2005 | 11:47 AM
mukundan's Avatar
OK Wiking! I learned my lesson! I need to take out that screwdriver and start the investigation. Do you have any website links on Fuel Injector replacement? The tools needed, DO's and DONT's etc.
Thanks!
Old Nov 2, 2005 | 11:10 PM
Wiking's Avatar
...take out that screwdriver and start the investigation...
Injector swap will be the last one [for me] for stuttering engine:
- stickies; maybe craigs page?
- search the .org
- google
Btw. For the filthy rich, theres also the mechanics -s*** hos cope- maybe 6$. Youll also look respectable like a doc (or dog?) them hanging around neck...
Old Nov 2, 2005 | 11:35 PM
pingpong's Avatar
GXE back from the dead
i had sputtering problems with my '90. the problem was with the #1 injector...got it replaced and 3 months later it started again. instead of changing them out as they go out i changed them all. to save some $ i bought used ones from a salvage yard and had it cleaned and mapped.car runs excellent.
parts i bought
plenum gasket
upper intake manifold gasket
o rings (2 per injector)
fuel filter
carb cleaner (clean out air plenum while it was out)
Old Nov 3, 2005 | 12:35 AM
Wiking's Avatar
1. Havin problematic x, replacing y will NOT hlp.
2. Havin problematic y, replacing y will hlp. YESS, do it!
1 + 2 = Imperative FOR YOU is to differentiate between x & y; no amount of work, parts, pills & bill$ will NOT hlp if diagnosis is wrong. Repairing x&y is triple costly.
Go to a doc, in clinic or cars-hop. Definitely pills & diags will be sub$cribed. They will surely hlp...to Secure next 5$ promo -caribbeancruise for the doc. Hangin scope hlps.
Imperative FOR YOU is to differentiate between caribbean & scope ...pill$???
When goin to a 'doc', ALWAYS take second opinion.
Old Nov 3, 2005 | 03:00 PM
mukundan's Avatar
So far 3 injectors have gone bad in my car. 3 more to go!! Don't know how soon. Any ideas how to keep the injectors clean?
Premium gas? Does Ethanol play some role in this fouling of injectors?
From what I heard, none of the above seems to be the answer!
I am gonna get my Fuel Injector degree soon
Old Nov 3, 2005 | 11:43 PM
Wiking's Avatar
... how to keep the injectors clean?...
wrap in plastics?
as u get u degree, u can teach us what kinda plastics....
Old Nov 5, 2005 | 02:42 PM
jvstang's Avatar
my 1990 VG sometimes spudders around 2,000 rpm i can watch the tach go up and down as it spudders i havent figured it out yet
Old Nov 6, 2005 | 12:24 AM
Wiking's Avatar
Originally Posted by jvstang
... it spudders i havent figured it out yet
I wrote a novel about that http://www.cardomain.com/ride/748507/1
Old Nov 6, 2005 | 07:54 AM
cruzanstrouble's Avatar
I had the same prob with my 90 a year ago after i put new plat plugs, and wires in. I replaced the rotor and cap and the prob went away. Pop your cap off and scrape the tip of the rotor clean with a flat head or something. If it works then you just need a new rotor.......
Old Nov 7, 2005 | 08:03 AM
mukundan's Avatar
Let me try to differentiate the 2 problems I had with similar symptoms:
1. Starting problem and dying (and the shaking was more violent)... noticed after I parked the car out in the rain overnight -- battery, rotors & cap.
2. Sputtering (listen to the exhaust - you will surely notice it) and bad mileage -- fuel-injectors
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
