cylinder 1 misfire - please help
Old Nov 7, 2005 | 04:23 PM
azrael's Avatar
I just recently changed my sparkplugs (platinum tipped of course), and since then, I have been getting the error code for cylinder 1 misfire. After some deducing (moving sparkplugs and coils), I found out it was the ignition coil....the rubber boot at the end is worn and the current is arching elsewhere. I bought a new ignition coil and installed it today. After a few hours of driving, it began to idle rough again and the check engine light came on. Again, the error code was for the cylinder 1 misfire. Having new sparkplugs and new ignition coil, how is this possible? Please help. Thanks
Old Nov 7, 2005 | 06:48 PM
L.I. I30t's Avatar
It is possible that the coil was not installed properly or you may have a defective coil. Switch it around a see if it happens again with another cylinder. also check that cylinder's spark plug, it may not be seated properly.
Old Nov 7, 2005 | 07:00 PM
njmodi's Avatar
Do I get a tax break?
Perhaps that plug is faulty. Did you try swap the plugs between two cylinders and see if the misfire moves with the plug.
If you've swapped coils and plugs and the misfire stays with the same cylinder (i.e. #1) then you may have a bad injector.
Old Nov 7, 2005 | 07:55 PM
azrael's Avatar
Thanks guys for the input. I'll check it out tomorrow at first sign of daylight. I'll keep you updated
Old Nov 7, 2005 | 11:22 PM
MrDicks95SE's Avatar
Offset Is Everything.
im having the same problem. just hope you dont have a bad injector cuz #1 cylinder injector is under the plenum.
Old Nov 8, 2005 | 03:03 PM
azrael's Avatar
Found out the injector was 'defective'. Had it replaced, but the autozone computer said I have to replace 3 of them. So I'm really not sure if compatibility with the other injectors was a factor. I'll find out soon. So far, it seems to be fine...and hopefully, it stays that way.
Old Nov 8, 2005 | 06:11 PM
njmaxseltd's Avatar
The Autozone computer is set up to "upsell".
You didn't need 3 injectors, only the one that was bad.
Basically, you got taken for with the purchase of 2 unneened injectors.
Old Nov 8, 2005 | 06:13 PM
njmodi's Avatar
Actually I think he only replaced one, and was hoping not to run into any compatibility issues... at least thats how I interpreted his post:
Old Nov 8, 2005 | 06:16 PM
azrael's Avatar
Yep....I never did buy the other "required" two injectors. I'm playing it as cheap as possible
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
