Soft Touch Courtesy Light Mod
Hey all 4th gen's we came up with a new mod some might be very interested in, pretty much ill let this video clip explain itself. it took me about 1 hour to install all the touch sensors, and its easier if you have sunroof, im in the process of making a lil writeup as I say in the video. enjoy
http://media.putfile.com/95-99-Maxim...tesy-Light-Mod
yea i installed it pretty much at the B pillar like above the seatbelt. since thats the most access u have closest possible to the light and to the rear seat., i was going to put it in the back pillar but then the person would have to reach back and tap above them, also i didnt wanna use up that much cable either. so i think its fine right above the b pillar
Just to let u guys know, this is a very simple install. The only thing that you really have to spend time with is adjusting the sensitivity on the sensors... but that's a simple turn of a flathead slot.
well ill just show later wen i finish the writeup. its cuz im at work n stuff so it will take a bit for me to do the writeup. the sensors can be purchased on ebay. ill let u kno later wat u need.
Originally Posted by ThurzNite
hmm... how about a soft touch push-button engine starter and stopper? Match it with a proximity sensor that's attached to your keychain and you're good to go.
Jae
Jae
Jae
Jae
I can imagine (when on potholes), all these vibration sensors would go nuts (depends on the sensitivity too I suppose).. I can just imagine driving through Chicago with all my lights turning on and off automagically with each bump.
Its reversable, you can just remove the sensors and hook up the wiring back to stock, so if you dont like it you can remove it. As far as bumps, we had that problem at 1st, but we turned down the sensitivity enough so that it'll only come ON when the vibration is within more or less 2" around from the sensors. Big bumps like train tracks tho (if you forget they're there and dont have time to slow down til the last second like happened to us) will still set it ON, but on a regular basis it shouldn't happen at all.
BTW, the light's ON/OFF switch is still functional, but to have the sensor feature activated the buttom must be left in the ON position.
rgr that. it takes a bit to get used to and adjust. its like a viper alarm for example u gotta get used to the sesitivities and adjust them with time to get the settings u want exacly. but other than that. its a great and cheap mod.
Originally Posted by CreativeDesignz
idea is great but when u have around 154db of bass i think the sensors would go insane. not to mention if i wanted it to work i would prob have to punch the sensor.
NICE. njmodi beat me to the possible downside though.
i duno, its not that hard to push a button, i mean, you've already lifted your arm that high, might as well just aim it properly... although if yer drunk it could be good, but then again, don drink and drive.
I think one of those sensors would be nice on the electronic door for the gas tank that the I30's and now some maxima owners have. Just tap that sh't right by the gas tank door and it would open. Of course you would have to use a relay so it couldn't be opened when the doors were locked.
Originally Posted by s0ber
Yea StreetZ, wheres that writeup??
Oh I heard 95BLKMAX has the writeup, you guys can PM him :-)
