thumping nosie coming from the wheels???
Old Nov 17, 2005 | 12:23 PM
red-line-racer's Avatar
LOUD thumping noise coming from the wheels???
just bought a 5 speed max off of a member here. just yesterday i was driving and i here a loud thump when i shift to second gear and let go of the clutch fast sounds like something lose but don't see or feel anything???
it something it does it and sometimes dosent i need any ones help it kind of worries me the it might leave me stranded. thanks 4 the help...
Old Nov 17, 2005 | 12:57 PM
andy044's Avatar
RWD bolt-on conversion?
if you're letting go of the clutch fast, it could be the throw out bearing. but that wouldnt be coming from the wheels. that would be right in the engine compartment.
its an old car, and if the tranny has never been redone, you might not want to drop the clutch like that? but it shouldnt leave you stranded.
is it only in second?
it could be too much crankshaft end play.
eithert that or your spare tire isnt bolted down tighly
Old Nov 17, 2005 | 01:03 PM
but it also did it once when i was going in reverse
Old Nov 17, 2005 | 01:53 PM
Greeny's Avatar
¯\(°_o)/¯
Check the motor mounts......
Old Nov 17, 2005 | 06:49 PM
how do i do that???
Old Nov 17, 2005 | 06:57 PM
vansskaterfreek's Avatar
look for the little things that hold the motor up
Old Nov 17, 2005 | 07:02 PM
i know what it is what i need to know is how do i check it if its good or not
Old Nov 17, 2005 | 07:11 PM
decus's Avatar
If they are really bad u should be able to tell by looking at them (broken/missing rubber is a bad sign).
Otherwise, have some one in the car and get them to hold the brake in. Put in drive and bring the revs up a bit then try it in reverse (if its a manual release the clutch a bit to load up the motor) and observe whether there is excessive movement at the mounts.
Old Nov 18, 2005 | 08:34 AM
yay0's Avatar
How hard is it to replace the rear mount + transmission mount? The owner before me snapped the e-brake cable a while ago and just parked the car in gear everywhere and never replaced the cable.
Old Nov 18, 2005 | 01:19 PM
today i checked the clutch fluid today and that s*it way low its below the minimum level could this be the thumping noise i hear (motor mounts are good)
Old Nov 19, 2005 | 05:00 PM
internetautomar's Avatar
mod or sell?
fill it and find out
Old Nov 20, 2005 | 04:03 PM
Ford5.0forlife's Avatar
dont beat on it you'll be fine.. as long as its a thump and not a whining/grinding, you should be fine (tranny mount? maybe)
homeyclaus
Sep 3, 2015 06:15 PM
Economic_Rage
Aug 20, 2015 08:27 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
BassAddictJ
Aug 4, 2015 11:38 AM
