Starting problem...sensor?
Well i have a 98 max. and ive been having this starting problem. i took it to a guy who said that it is some sensor on the intake manifold? that he said it is around $700 to$ 1000 to fix. whats happening is that if i put in the key and turn it the engine will just keep cranking and priming the fuel and will flood the engine. so what i have to do to start it is to turn the key and hit the gas pedal and it will eventually start. right after it starts there is a lot of smoke blowing out of the exahust. so anyone know anything about this that can help me out here?
Wow he is truely trying to rip you off.
Like Nmex posted, could be crank pos, or simply a dry starter that takes a while to crank.
You decription sounds just like when my starter was going. Took about 4-6 cranks eventually fired up, black smoke out the tail pipe. New starter cuered it all.
Truth be told, there are any number of hard start reasons. If you have not error codes, I would not play the part swap game but instead, bite the bullet and have the dealer take a look at it. He will recommend what needs to be fixed and you can decide at that time if you want to fix it yourself.
Before you do that, make sure your car has had proper up keep: spark plugs, fuel filter, throttle body clean, battery (incl. fluids), etc.
Let me know.
I used to have similar problem starting my '95 Max. Pulling the codes indicated a crankshaft position sensor fault. After taking off the sensor (side of the engine, toward the bottom by the oil pan on the passenger side - 2 screws), I found that the top was covered with 1/8" of road grime. I cleaned it up and checked it with my meter per instructions in the Haynes manual - tested fine so I reinstalled it and starting improved immediately. Apparently the heavy layer of dirt was interfering with the sensor's abilty to operate properly.
Have someone check your Starter for you, it should not take long or take it to a nearby Autozone where they will test it for free. If its good it can be one of the following to my knowledge. Crank Position Sensor, Coolant Temperature Sensor, or maybe a bad ground. Have you checked the fuel filter and the fuel pump. Try running a pressure test on the fuel system.
Hard crankin after car sets
I had new fuel filter put on, injectors cleaned. Only does it after the car is parked for 30 min. or more. Any thing short of that it's ok. Having coil problems along with this starting thing is very annoying. I'm replacing the coils. Found them for $59 here in Birmingham.
Originally Posted by tavarish
i wouldnt do this. If you want, I'm in elizabeth NJ, and I can check out your car for you. I've had this problem and fixed it, and we can swap parts if necessary. And i'll do it for free. Nissan dealer's won't do that.
Let me know.
Let me know.
Originally Posted by xmaltbeerxcp
actually i might take u up on this...i slept over last nite in jersey city over a friends house and my freakin car died! couldnt get it to start damn it lol. i'll see what happens anyway. how hard is it to change this crank pos. sensor?
Wow guys sorry for the really late post on what I did to fix it. Anyway I took it to my friends mechanic and turns out it was the starter like most of you said and the knock sensor. Anyway thanks a lot for all your help and advice I know some people here wanted to see what my problem was. Again sorry for the late post.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
