Pic of my new engine (slapped a little paint on)
Ok this is Altima engine I bought to put into my 95 GXE. Cleaned it up a bit and sprayed a bit of paint on.
Cams are going in just as soon as I get them back from Rob (Tilleys99) Hope I don't take too much of his time telling me how to get the cam timing correct.
It got me too, I was thinking why does the altima engine look like the vq30
Then I saw Nismo3112's post and realized that was his sig.
How much did the engine run you if you dont mind me asking?
Then I saw Nismo3112's post and realized that was his sig.How much did the engine run you if you dont mind me asking?
The valve covers are 3.5 its just the plastic 3000 sign from my old 3.0L, don't want to advertise the 3.5 just keep it low key. The plastic cover for the 3.5 was broken when I got the engine and they just hold heat in anyway so I was just about to throw the old 3.0L sign away when I thought I would see if it would fit. Its going to take some additional holes because the originals don't line up with anything on the 3.5 valve covers and some plastic dremeling but it should be good for a laugh.
Originally Posted by NmexMAX
Check his sig...
... Turn on Sigs ... and pictures on options menu.
... Turn on Sigs ... and pictures on options menu.I had sigs turned on... my internet options somehow changed.. couldn't see offsite pics.
It's all good now.
Looks nice Jim.
Originally Posted by chilled
Im my opinion getting subs that heavy/loud is a waste of time and good money also.
anyways, the engine looks hawt jime
I thought it was a VQ30 until I saw the oil cap :-\
Alex everything got painted, the hardest was the timing chain, trying to get into all the little places you can't really see. It was easier to paint the injectors than cover them up so I just covered the connector.
I did the transmission today that was worse, took me 2 days to clean it, was really nasty. Now I want to try and keep it clean. My Son tells me its much easier to keep the painted surface clean than bare aluminum.
Originally Posted by Jime
plus the new Dulobz cams should perk it up a little.
ebay $699 jwt copies?
oh yeah a big tip: make sure to use high temp clear coat, that way wiping the dirt off is a snap, and no residue on the paint with a nice glossy appearance, also great for brake calipers, Duplicolor Makes good high temp clearcoat.
that vq should be putting down some nice times either n/a or N2O'd
keep on tuning
Originally Posted by vipervadim
what cams are you referring to?
Originally Posted by JClaw
So you bought the cams Jim?
Ya and its all your fault. None of this would have happened if you would stop advising people about what to do.
Now I just may have to buy those to beat you at CSCS next year. And you and krismax have brainwashed me with weight reduction.
Ya they are testing them on the Altima forum now, one has dynoed and the other is this week. Looks like around 15-20 HP. Rob has mine now for drilling and says they look really good. Now is the time to install them while I have the engine out and opened up.
Exactly what I'm using.
a couple times before actually noticing.
Shudup.
my kid will be a nissan guy for life after i corrupt him!
