Rear suspension diagram?...
I tried searching for a good 20 minutes.. all the links I found were old and the pictures were taken down. Need a simple diagram of the rear suspension to make sure I'm reassembling it right, its been a long time!
-Cyrus
-Cyrus
http://www.kcmaximas.org/tech/suspension/index.html pics of the parts themselves.
Ok for my rear suspension I have the AGXs, KYB dustboots/bumpstops, Tein H-Techs, and Ben's rear strut mount plates. I need to know if my order should be as follows:
KYB boot/bump -> upside-down bronze bowl -> star bushing (56218-61L10) -> strut mount -> smaller rubber bushing (56217-61L10) -> dish-shaped washer
My problem is that with the KYB boot, I don't have room for the star bushing. Should I be cutting this in half? If I don't, when I tighten the strut top bolt, the star bushing is so compressed that it pushes the KYB boot/bumpstop below the notch on the AGXs, basically making them useless.
Thanks,
-Cyrus
Thanks,
-Cyrus
Thanks,
-Cyrus
Thanks,
-Cyrus
The thing I circles, if I put that on, the KYB bumpstop gets pushed too far down. Should I trim it in half or leave it off?
-Cyrus
have you tried assembling the pieces without the spring, just to make sure everything fits fine?
I didnt notice till I was pretty much done with putting on the new suspension but when you get the kyb boots they advise using soapy water to help get the boots on and down. Did this on the last dustboot that had to go on the car vs. museling it/cutting it.
Ok thanks guys I guess I am going to leave that star bushing off and let the bronze bowl hit mzmtg's mount. I think that when all the pressure on there shouldn't be too much movement/clashing of the two.
BTW I've had my KYB boots for about 2-3 years now... I know most people say they rip a lot, but I Vinyled them when I put them on and they're still tear-free. Of course the car doesn't move much, so that could influence it also...
Thanks,
-Cyrus
Thanks,
-Cyrus
Well I learned the hard way, it's definitely needed. Either way my bumpstops wound up beneath the notch on the KYBs, and the bronze bowl would rattle a ton.
Case Closed.
-Cyrus
Case Closed.
-Cyrus
Case Closed.
-Cyrus
Case Closed.
-Cyrus
