Installing Redlinegood shift and ebrake boots?
I got my relinegoods shift and ebrake boots in, in the mail a few days ago. I looked at the insatllation instructions they give online and it says you need to use the factory metal rings that are in the bottom of both the shifter and ebrake boots. Is this what everyone does? Or can you use a coat hanger? I am wonndering because I would rather not cut good boots up.
-matt
Originally Posted by matty
I used the factory rings on my shifter and my E-brake boot. Both were so far gone and ripped it really didnt bother me to cut them up. Isnt that why you bought new ones ???
-matt
-matt
i cut the originals in one place b/c that's what the instructions say, but i couldnt get the rod through the seams, so i ended up cutting the thing into 4 pieces. it worked okay for the shift boot, but for the ebrake boot you need the rod to actually form a shape to keep it in place so it didnt work. the next day i tried to push the rod through with a little force and it worked. you can use a coat hanger and form a new ring. it will be a little thicker, but you should still be able to get it through the seams.
I got one from the junkyard from a ford taurus SHO, i took the metal ring out cause it didn't fit my auto shifter trim, and i just crazy-glued it to the bottom of the shifter trim. it's actual leather, and it looks really good...especially cause it was free.
I am going to try working on this again tonight. I plan on reusing the metal ring out of a perfectly good ebrake boot. for the shifter boot I am going to try a coathanger since I do not have an extra boot to canabolize for this. Ill report back as to how it goes.
MaxLife17
Jun 27, 2019 01:37 PM
bryants95max
Oct 2, 2015 12:52 PM
lowpost99
Sep 8, 2015 05:06 AM
