Detailed AE Mod Write-up with Pictures!
Old Dec 5, 2005 | 04:39 PM
Maximized2000's Avatar
Hey fellow Orgers,
I did a detailed (step by step) write-up with pictures of the AE Mod over the weekend.
Take a look: Page Three in my cardomain page
http://www.cardomain.com/ride/2190617/3
Enjoy!
With the help of Pri63's and Icelandmaxima's Writeup..thank you!
Old Dec 5, 2005 | 04:55 PM
irish44j's Avatar
retired moderator
looks good man....I did this a couple years ago when I had my stock headlights.
Old Dec 5, 2005 | 05:19 PM
Yeah, I think I'm staying with my stock headlights and upgrading later to an HID kit. The headlights definitely looks better with the AE mod. I can't wait to put them on.
Old Dec 5, 2005 | 05:47 PM
TPenguin's Avatar
Got Penguin?
Where are the retaining tabs for the lights located... i looked and couldnt find them to do some cleaning... thanks guys..
Old Dec 5, 2005 | 06:53 PM
makdaddy386's Avatar
What retaining tabs are you refering to?
Old Dec 5, 2005 | 07:01 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have three OEM 01 headlights and wil ldefinetly will be doing this ... I like it but I love my HIDS....
Old Dec 5, 2005 | 07:09 PM
fatboyslim86440's Avatar
hey could you do something simular like that on a 3rd gen?
just wondering
thanks
Kyle Cisneros
Old Dec 5, 2005 | 07:32 PM
just wondering
thanks
Kyle Cisneros
Not really sure if you can because of how the headlight housing is on the 3rd Gen. You could definitely do it on a 4th gen.
What retaining tabs are you talking about? Not really sure?
Old Dec 5, 2005 | 08:05 PM
alright
thanks man
Kyle Cisneros
Old Dec 5, 2005 | 11:50 PM
TPenguin's Avatar
Got Penguin?
Well i took off the top two bolt but i must be missing something.. what else do i need to take off to get the headlamp assembly off?
Old Dec 6, 2005 | 12:16 AM
PandaXpress's Avatar
very nice writeup i was just searching for something like this..what is the odds i find a detailed writeup right in the knick of time. thx.
Old Dec 6, 2005 | 05:42 AM
I worked on a set that I bought from an org member so I didn't really get a chance to remove my headlights yet but I read that you take off the two bolts on top and there are clips on the bottom and on the side (by the signal) that holds the headlight in. Make sure not to break the clips by forcing it out.
Whoever has taken their headlights off please correct me if I'm wrong.
Old Dec 6, 2005 | 05:51 AM
jeremyd72's Avatar
That looks good man. I plan on getting a 2001, and will try that.
Old Dec 6, 2005 | 07:29 AM
upstatemax's Avatar
Nice writeup, I have not done this yet because I was afraid that if I mess up a headlight... I have no car till I get a new one. But the Max will be sitting all winter so I will do it then.
Old Dec 6, 2005 | 07:40 AM
honestly, at first I thought taking the headlight apart would take a long time but it only took about 25 minutes and i didn't have that much trouble. The step that took the most time was rubbing off the chrome. It took me a long time to rub all the chrome off cleanly.
Old Dec 6, 2005 | 09:15 AM
There are two 10mm bolts on the top of the headlight housing. Once removed you will want to pull the headlight out the front of the car, not up, towards your body. Pull the inner corner of the light until the corner pops out past the grill. Now there is still a metal snap rod that is on the marker corner that you will need to pull out as straight as possible. This will ensure that you will not break the plastic retaining clip that locks it in. In this picture you are looking at the metal snap rod. The housing is lens down, with the marker side closest to you. The right side of the picture is the top of the headlight enclosure as you can see one of the supports that you pulled a bolt out of.
Be patient, this is the key!
Kevin
Old Dec 6, 2005 | 09:57 AM
icelandmaxima's Avatar
Maxima Fanatic
As much as I love the 2k2 headlights I still think the AE-D headlights look great
Old Dec 6, 2005 | 03:55 PM
ZIPPIN's Avatar
Mauja He Mauja
do the 2k2 lights also have the peel off chrome??
Old Dec 6, 2005 | 04:04 PM
NewLoveI30's Avatar
I wish I would have known this before I painted my I30 headlights. Although I guess I did want to go with a matte black instead.
Old Dec 6, 2005 | 06:07 PM
I believe that you have to paint the '02 headlights. Don't quote me on that, but every post that I have read on the subject says that they painted theirs. If you pop it open make sure to make a clear lens for the indicators.
Old Dec 7, 2005 | 06:07 AM
It would look hot if you could just rub the chrome right off the 2k2 headlight. I guess trying to open up the headlight will be the same as the 2k one.
Old Dec 7, 2005 | 06:14 AM
VRod's Avatar
when you polished the plastic did you follow what was done in this thread
http://forums.maxima.org/showthread.php?t=443410
if not what brand of polish did you use?
Old Dec 7, 2005 | 06:36 AM
kcowden's Avatar
Did you polish the inside of the lenses? Mine seem to have a haze on the inside that is somewhat annoying.
Old Dec 7, 2005 | 07:35 AM
When I did mine, my headlight was not really scratched up like the one in the other thread. It just had tiny scruff marks and a yellow haze. I just used a scratch remover that I got at Walmart and it help a little bit (not great though).
I didn't use anything but a soft no-lint cloth to wipe out the inside. At first I thought the haze was on the inside but after I opened up the headlight, the inside was fine.
Old Dec 7, 2005 | 09:25 AM
Read posts #20, 23, and 24 to find out what I did and see more results.
Old Dec 8, 2005 | 07:13 PM
carabuser's Avatar
good job man. I just smoked my taillights and was going to do this some time soon. Looks like a winter-break project.
Old Dec 9, 2005 | 06:38 AM
Thanks! Its definitely a winter break project. The OEM headlights look good but when you do the AE mod to it....it looks GREAT~!
James92SE
142
Jan 2, 2024 09:23 AM
lrb6805
Sep 30, 2015 08:12 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
16_SR
Sep 7, 2015 06:47 AM
maxfever1987
Sep 6, 2015 06:20 PM
