V-AFC VIAS Engagement?
Sorry if this is a repost, I tried to find some information but nothing adequetly answered my question- can you use the V-AFC to trigger the VIAS on a 00VI? Also, please correct me if Im wrong but as I understand it the V-AFC is everything the S-AFCII is accept with the added VTec hi/low cam activation points for acceleration and deceleration?
Originally Posted by blazingchimp
there are some more differences then that but yes in short it can act as an rpm switch for the 00vi. I have that setup and it works great.
Originally Posted by Ceasars Chariot
chilled any leads on where you plan to buy your V-AFC ? i have to start shopping around as well
Don't know if was just me & my ghetto wiring skills but I could not get the VAFC to actuate my VIAS. I know the VAFC-II will work though.
I still need to mess around with it somemore when I get a warm place to work on it. I'm using a RPM switch now.
Just a heads up!
Just a heads up!
hmm, I hope the VAFC-II doesnt give me any problems because I just sold my SAFC and Summit RPM switch and got the VAFC-II...
Does the VAFC give you a output signal wire and have you tested it with amultimeter to see if its giving out any voltage when the switchover point is reached?
The VAFC II will be fine.
I've been through most troubleshooting issues with the 1st edition. Weird thing is I've got it set to power my RPM switch so I know it gives power at the "VTEC" engagement point.
Originally Posted by SDot82
I'm actually about to do another VI swap up here like this weekend or next (it's a 96 SE 5sp).
You need to give me a call so I can come join the party. You wouldn't believe how much quicker my car is now that I don't have a sensor blocking an intake valve.
I'm using the VAFC-I to power my RPM switch at set RPM, even though I have the RPM switch set higher. Cheese way to do it but anywho.
Shawn - I did try a new ground point at it still doesn't activate, I think that's why on the VAFC-II they have the low, med, high "VTEC" setting.
Also if you talk to anyone looking for a 14.4 sec Maxima I'm looking to sell mine $8500
boomerbrian
Oct 31, 2018 10:25 AM
