New owner 5th Gen-Also coolant question
Old Dec 7, 2005 | 06:39 PM
5thgenmaxima's Avatar
Bought it today.
Unfortunately, It's not as cherry as I thought. It is a GLE with spoiler added. (Factory, after looking again it does have a light) Carfax checked out ok. It has a small dent in the front fender tire well. (Quarter sized). A few paint nicks on the front bumper, and a small amount of surface rust on the inner lip of the rear quarter panel, (Nothing that can't be lightly sanded and fixed) and there where a crap load of weghts on the tire to balance it. (Yea, I try to be thorough, this tells me he probably smacked a curb.)
I also put the car on a rack and hooked OBD II up. No stored codes, nothing. No misfires, all 02 banks are running good.
Now the other problems besides from the exterior are two things..........
1. It needs a passenger side wheel bearing... I figure $50, no biggie.
2. It was low on coolant.... It's been sitting for a few weeks-He says-...... It was to dam cold to sit outside and do a pressure test,(3 degrees F) though I really wish I would have. ....Anyway's, are these cars known for using small amounts of antifreeze or did I buy a headgasket problem??? Any TSB'S for coolant loss?--I suppose I will check FAQ, but thought someone would know common reasons and/or problems pertaining to coolant loss.
It also has 59,000 miles. paid 10,200 for it....Not great, but not bad right? be brutally honest if you must.
Old Dec 7, 2005 | 08:24 PM
.bump........Come on, Opinions are like *******s everyone has one......I am interested in hearing yours, and like I said be honest. I can take a punch or a "good deal"... Let me know what you think.-
Old Dec 7, 2005 | 09:48 PM
Ok, maybe a few pics will help?? First cardomain site--There are 4 pics.
http://www.cardomain.com/ride/2195944
If you copy the third pic into a paint file and zoom in you can see the small dent I'm talking about.
Old Dec 7, 2005 | 10:27 PM
TPenguin's Avatar
Got Penguin?
00 Gle
When I got my 2000 GLE I Flushed the radiator flush because the guy just changed oil... I was suprised on how little radiator flush mine used compared to my MDX and Oldsmobile... I wouldnt be too worried but watch the level if it drops then i would investigate a bit deeper...
Old Dec 7, 2005 | 11:39 PM
† ErV †
no, they do not lose coolant. i flushed mine ~2 years after i bought it and in that time i didn't lose an ounce. talking about 60k miles at least in that time frame, southern heat including FL.
Old Dec 8, 2005 | 01:18 PM
Ok, all seems fine - No overheating - no more coolant loss just the original that small "top off". -Everything else checks out ok except mentioned problems. Did I get bent over with price or is that just about right????????
I also called the dealership to see what was done under warranty
@38500 miles tranny flush, gasket, and filter.
@39000 miles reman tranny....are the remans the same as original or did they fix the faulty parts. I.E. better clutch packs, bands, bearings, etc??? (Whatever the main problem in these trannys are). Just wondering if I should expect another tranny sometime down the road.
Old Dec 8, 2005 | 09:01 PM
Another quick bump for opinions if I got ripped or not on price????
Also the wheel bearing was fine. It was a tie-rod end, that's an easy fix and will be fixed early next week, then it's to the shop for an alignment. Cringe.......Guess I'm going to have to find one with lots of windows into the shop from the wiating room. It's to dam cold to be "smoking" non-schantly (If that's how you spell it) outside in front of the baydoor where he's working on it at.
Old Dec 8, 2005 | 09:04 PM
carsarecool's Avatar
I dont think so, check the KBB and NADA values, but check both since kelly is low and nada is high but 10,2 for a 2000 GLE isnt bad, what 59,000 miles? Thats actually a pretty good price, i paid 12 for an 01 SE a few months ago..
Old Dec 9, 2005 | 04:24 PM
misiek's Avatar
paid $12000 for a 02 se with 30,000 on it.... so im guessing you got it about right considering you have the luxury part of it
Old Dec 9, 2005 | 04:28 PM
Very nice..... Around here noone will go less than KBB dealer price. (And that's suppossed to be a beginning point), Then again there are only 2 5th gen's for sale locally and are hard to come by....
My primary reason for steering away from the 02's is because of the 3.5....Come to find out my 00 is scaled as a 19 (higher is more expensive) at my insurance agency. The 02 is the freaking same. Wish I had called sooner. Didn't expect an 00 to be that high, considering my 4 Wheel drive SUV was at 11.
Old Dec 10, 2005 | 09:38 AM
super6's Avatar
sounds like a middle of the road deal to me not terrible but not great either. by the way u didnt mention what year it was? ive never heard of coolant loss problems either. not to bring u down but unless u were looking for a gle, should have gotten an se, not a big deal tho, can always swap suspension and tranny...5spdddddd! good luck with it man!
Old Dec 10, 2005 | 10:00 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
just flush the radiator... and do all require maintenance.. The Max is a great reliable car.... so treat her well and she will treat you good as well
MAXSE5SPD
Sep 17, 2022 04:00 AM
MR2 T'd
Jul 9, 2021 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
