No Heat......Let's try this again!
No Heat......Let's try this again! Experts please!~
Ok I have had no or minmum heat for the past 2 years. I had the heater core replaced, due to it leaking. The radiator replaced due to a broken neck. I replaced the thermostat but still no heat. It usually comes out luke warm if any. NOW on occasion I have had some heat when I manually open the heater core valve by holding the on/off button on my ac controls then pressing heat up 2 times, then the defrost button......that manually opens the heater core valve but as soon as I turn the car off and back on the little heat that I was getting is gone.
I brought it to a radiator place and the mechanic tells me "It's either a electrical problem with your auto a/c control or a mechanical problem".....no **** sherlock.....and it would be $150 just to diagnose what it could be. I did notice and the mechanic said that the heater control valve on the firewall doesn't do anything, if it's open all the way or closed it doesn't make a difference as to how much heat i get. Something else I have found out is that the heater hoses going to the heater core the ones going in are hot but the one coming out is not. So that either means that my heater core is clogged [which i don't think it is] or that some flap or door that is suppose to open to allow hot fluid into the heater core isn't open up. Can this be caused by a faulty auto climate control or is it just a bad flap? Is this flap or valve controlled by vacuum or is it electronic? I just need help to figure out what is going on.
Fluid is filled all the way as well.
Originally Posted by njmodi
I remember your original thread on this (a few weeks ago)... I would bet your heater control valve is not working properly... how much is a replacement?
Where is it and what does it do? If you are talking about the valve on the firewall, with the cable running to it? It doesn't do anything, the cable doesn't retract it at all no matter what temp I put the controls on, which leads me to beleive that maybe the problem is with the auto climate control unit. But if i dis-connect that cable and manually open and close that valve it still doesn't make a difference as to the heat i get as well....so I am back at the begining again.
I have had the system bled and refilled twice and each time they tell me the heat is working perfectly now. I go pick it up and heat works great only to have it go away the next day or 2
But then you say that manually operating the valve doesn't change the heat either, so
maybe the valve is never opening, i.e. even manually operating the cable doesn't actually cuase the valve to open - the mechanism might be broken.. If I'm not making any sense
it's because I've never actually played around with the parts you are talking about and don't even know what the valve looks like
