What gives, alternator, iac valve?!!
Background- Alternator replaced 2 yrs ago, battery 1 yr ago
Here's the deal, within the last week and a half, when slowing down to a stop, when I step on the clutch, the rpms are dropping down to 3-500 rpms for a like a brief moment when I stop and then they go back to normal. A couple of times I noticed the battery light come on for like a second then go off. The serpentine belt was making some noise so I replaced that figuring maybe there wasn't enough tension. Today I noticed the same thing happen and battery light come on twice and actually held for like two seconds then went off.
I dont know what to make of it. Maybe a dirty IAC valve??
BTW..all this seems to have started when the temps dropped to like 20 around here..
Originally Posted by njmaxseltd
Clean the throttle body and IACV valve.
The battery light is coming on because the idle speed drops to low for the alternator to put out the correct voltage.
Makes sense. Thanks Tom! I had a sinking feeling that was it but I wasn't 100% sure. This is going to be fun to do in the freezing cold never mind the snowstorm!
Originally Posted by BigLou93SE
Would it mean anything if the engine behaves this way in any weather, and does not produce a battery light?
**update on IAC Valve/ TB issue
However, I'm still having the battery light come on when I do stop. I've noticed that this is happening at night when I have the lights on. The curious thing is, if I step off the brake pedal, the battery light goes off and does not come on. As soon as I step on it again, the darned thing lights up as if I'm doing a roll call! This would indicate to me that I'm still having some sort of a drain on the battery. Is this where I finally panic and go get a new alternator, 1.5 yrs after the last install??
TallTom
57
Oct 14, 2025 05:16 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
