Cylinder 6 Misfire...
Old Dec 10, 2005 | 10:12 PM
Maxed_Out_Maxma's Avatar
So my CEL came on and the code read that cylinder 6 is mis-firing, and I posted this about a week ago and everyone suggested replacing the spark plug and checking the coil pack, but unfortunately, it was neither of those. So before I take it into the shop I was just wondering if their is anything else I could check... Also, cylinder 6 is the one closet to you and all the way to the right... right? Thanks for any suggestions. (Could it be a bad injector? How much would that cost to fix?
Old Dec 10, 2005 | 10:19 PM
f550maranello2's Avatar
could be a bad injector... it sucks cuz they are expensive... use an ohm meter and check to see that it has a 12ohm load if not thats ur problem....
Old Dec 10, 2005 | 10:51 PM
Jatan's Avatar
You can either buy a new injector or just buy a set of used ones like I did (check Classified section here or eBay)
Old Dec 10, 2005 | 11:10 PM
sachmo's Avatar
it could be done yourself, i have no confidence in my car repair abilities but i managed to do it myself. There is a guide on here somewhere.
Old Dec 11, 2005 | 10:22 AM
Anyone know the link for replacing the injector? Also, is there anything else it might be?
Old Dec 11, 2005 | 01:45 PM
NmexMAX's Avatar
dot dot dot ...
How did you rule out the coil?
To test the injector, well a cheap and easy way, get a piece of hose, turn the car on, use the hose as a listening aid, and verify that the injector is "clicking" like the other 5.
Old Dec 12, 2005 | 02:47 PM
I ruled out the coil pack becuase I took it down to AutoZone and had em test it and he said it was fine. So, the only thing left is the injector... does anyone know the link for replacing it? How much does one of those cost?
Old Dec 12, 2005 | 02:52 PM
NmexMAX's Avatar
dot dot dot ...
I would test the injector the way the tested the coil at AutoZone ...
Old Dec 12, 2005 | 03:21 PM
JwaxMax99's Avatar
http://www.cardomain.com/ride/443899/2
Old Dec 12, 2005 | 04:47 PM
greenmax95se's Avatar
i think im having the same problem. might be different cylinder. but also did you notice a large loss of power in the car? cause i did. i haven't checked my injector but i did check everything else, (plugs, coilpack, and if theres spark etc). i heard that dealerships can clean out injectors with a proccess of running propane through it or something? is this right for our maximas?
-rafal
Old Dec 12, 2005 | 04:50 PM
actually after checking the diagram of cylinder layouts, its my 2nd cylinder that messed up. urs is the 6th. anyone have any ideas on my situation aswell?
-rafal
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
