Gas smell from heater vent?
73k miles, every once in a while when i have the heater on (i have the digi climate) 75 degrees and up i'll get a gasoline smell in the car, mostly coming from the floor vents-i thought it was other cars in front of me leaking but its happened maybe three times now, anybody ever had a problem or experienced anything similar? I'm not leaking any gas, and it goes away when i hit the recirc button
does it happen when the car has been running for 10-15 minutes, until its warm, or does it do it when its just cold? if its just when the car is cold it might be a leaking fuel line near the manifold(this happened on my 94 max when i had it)
ok, i asked you that becuase my 94 maxima did that too. when it was cold it would leak fuel onto the manifold and when it got warm it would stop becuase the hose would expand. you might want to check for leaks anyways just to be sure. our 86 and 94 maximas both had fuel line leaks onto the manifold but we didnt catch the 86 until it was too late
it could be that may be on start ups that the car is runnin richer due to cold weather. Or maybe you have a cracked line that is leaking a little. My boys Altima was doing that and it famous for the 3rd gens.
Tighten the clamps on your fuel lines.
Its an easy first step that will most likely fix the problem. Cold weather is notorious for causing contraction of the rubber of the fuel lines allowing a small leak to start. Tightening the clamps will usually work to bridge the gap. If not, replace the fuel line and the clamps. Make sure to use clamps that are the appropriate size and are made for fuel injection hose...NOT wormgear clamps. If you replace the fuel line, don't forget to relieve the residual fuel pressure in the lines or you will get a surprise.
Ditto. And maybe next time you smell it you may want to pull over, shut the car off, leave the key on and look for a leak then, if you haven't already been doing that.
ok, i did that a few months ago when it happened in summer, but its not like an unsafe thing right? i mean i know its a gas leak but not something i should be driving a rental for until i fix it?
Should it become bigger and hit your exhaust manifold, it could be considered in the "unsafe" category then.
ef9
Oct 4, 2015 08:43 AM
