96 GLE Auto ****s Hard From 1st to 2nd
I have a similar problem, 127k miles, but was told not to worry about it. I've noticed if I'm going easy on the gas, when my car shifts from 1 - 2, I feel a very minor thump / jerk. If I'm accelerating hard, and the car shifts at higher RPM's, the 1 - 2 shift is perfectly smooth. Changed my tranny fluid, cleaned the screen to no avail. I'm not really sure what could be causing it...
my car suddenly started doing that and shifting pretty hard, not every shift, but many. then i got a code and my od light was blinking. i replaced my drop resistor with a low mileage one from a junkyard and it went back to shifting normal. (knock on wood)
Took my car once to a tranny shop that specialized in imports (that i trust)once my 97 hit 300KM and they said it's normal. As long as your not getting
codes and the hard shifts don't happen on higher gears you're ok.
They went into a complicated explanation about shift solenoids and about 5 minutes in they completely lost me. :/
There are two likely causes of a hard 1-2 shift. First check the 12ohm resistor on the driver's shock tower. It has an aluminum heatsink on it and a connector with two pins. If that's not it and your CEL light isn't on, you'll need to check and see if the temp sensor is open.
Yep, I've still got the jerk after doing the change.
by the way does anyone know about a filter at the bottom of the tranny, they said that i have to remove the bottomof the tranny and the filter is right there, is this true.....
Jime i think you are needed on this thread
There is no filter per se. There is a screen and it's designed to last the life of the trans. The best think to do is to flush it every 60K or so. If you can't do that, then at least change what you can get out of the drain plug every 30K. It's really pretty easy to flush if you just disconnect the pressure like (one with the bango fitting) and run it into an empty gallon jug (you'll need a few feet of 5/16 line for this). Start the car and let it fill the jug (takes a minute or two). Refill the trans and repeat until you have bright red fluid being pumped out.
As for the 13 ohms, that's fine. Does it still shift into OD? When the temp sensor fails it will shift hard 1-2 and won't shift into OD. See if your OD button still makes the RPMs jump.
Yeah, I was hoping it would go away too, lol, but I guess it wasn't a bad idea to change it anyway since my fluid was pretty dirty. From what I understand, the tranny filter is sometimes referred to as a screen, and you can usually get by by just cleaning it. I didn't change the fluid myself, but the guy who did it told me the filter was in good shape, just needed a little cleaning.
if it doesnt shift into OD u gotta change the temp sensor, right. Where is the temp sensor. I think my tranny is screwed cuz its not shifting into OD, but it could be this sensor?
i havent found anywhere to get a drop resistor online, but i did find people talkin about a drop resistor mod that disconnects the drop resistor sayin it makes the shifts more tighter. so i dont know what to do.
ok i found something it atleast shows me where it is and what it looks like but on the site they tell u how to rig it so u can turn it on and off either allowing the transmission to shif at full line pressure (whatever that means) or normally.
i bought one from a junkyard from a low mileage i30 for $15. go to your local dealer if you want new, they're only about $35 there.
James92SE
142
Jan 2, 2024 09:23 AM
Unclejunebug
Apr 2, 2016 05:42 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
