what size ratchet to remove 02 sensor?
are the sizes different on certain brands? because the stickies say to use a 16mm but i just ordered a sensor on the phone and the guy said the new one was bigger then that and that the one im my car is to. so now im confused
well the 02 sockets are more of a PITA atleast for our cars...others they maybe easier for...i had 3 sensors changed in about 10 min using an open-end wrench...took me 5 mind to try and get teh socket on th right way so i said f-it
I had no problem with taking off the 02's when i installed my y-pipe, but the wire was a little bit hard to work with. just make sure to put lots of wd-40 on it to loosen it.
i used an 02 sensor socket.
Originally Posted by speed racer
The O2 sensor should be tightened to 30 - 40 lb-ft. Isn't it a 19 mm wrench. I like using the metric system.
Thank you. I still dont understand the usefulness of 7/6th or 15/16th, verus 14mm, 15mm. I just dont get it...
Metric just logically makes sense. . . but dont let me ramble on.
Jime where did you get the crowfoot o2 sensor?
http://cgi.ebay.com/ebaymotors/NEW-O...spagenameZWDVW
I have the standard O2 sensor which is the first socket in the picture, but the second one is good for those hard to reach spaces. But, I guess also the adjustable pipe wrench will work. I allways find them usefull for stripped nuts.
ballerchris510
Sep 23, 2015 08:46 PM
