I Think My Engine Is Flooded
Sounds like a CPS, starter or ground problem... Do you have a CEL? If so check codes.... My guess is 0407.. If not, find an extra car and take the starter out and to AutoZone to see if it's any good. In between all this check ground points.
Yes, you can definitely flood an EFI car. Mine has done it twice randomly. All it took was removing the fuel pump fuse for a second, but still...completely random. Hasn't done it since for awhile either
Man, what a bunch of bad advice. How can it be the starter when he says it "cranks but doesn't start"? If it really was flooded (unlikely) it would clear itself in 15 mins or so. If it cranks and still doesn't start then you either don't have fuel or you don't have spark. First thing to do is spray a little ether in the intake and see if it fires (some use a as soaked rag which always seemed risky to me).
My car was being
and cranking, but not starting.I thought it was the battery so I swapped them, and still, same behavior.
Ended up taking the starter out and to AutoZone, where they tested it, and it drug really bad.
Got a new starter under warranty, took it home, installed it, and it cranked and started as if it were brand new.
So I do not agree with you 100%, that it's not the starter, it could be a dying starter.
i dunno, but my car has had the same problem since it got cold. i dont know why but it will take 15 seconds of cranking the starter sometimes to start, and then if i dont hold the rpm up then the car dies five seconds later and i have to start all over again. i have a rear o2 sensor code, but i think my car is just retarded. it did come from texas-maybe thats why
James92SE
142
Jan 2, 2024 09:23 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
