Tein S Techs owners... Good or Bad?
Hey Guys, Just looking for some feedback from people who are using Tein S Techs springs and if they've had other springs in the past to compare, thanks in advance
I just swapped my D2s for Tein S-Tech with KYB AGX and I like them quite a bit. To me they are a really good street setup but I could see how some people would think they are a tad harsh.
I haven't played with the dampening yet so I don't really know their limit yet as far as handling goes. My front is also a bit lower than the rear (5sp).
I had them they road great. I always heard from others that they were harsh, bad ride, but the majority who said that never had S-tech. Bought them and had them on, and they werent anywhere near as bad as I thought. Still pretty damn smooth, I thank stock wheels for that but I never regreated purchasing them one bit.
And hot damn I love the stance it gave my car.
Originally Posted by nismology
A step in the wrong direction. Not enough suspension travel at that low of a ride height with a spring/strut combo. Furthermore, Illuminas > AGX...
Did you have S-tech and have travel issues?
I have S-tech/Tokico blues on my turbo car and had GC-AGX on my NA car. S-techs are not low enough for my taste, though they ride much nicer over rough roads than the GCs did. I'd say they aren't bad springs as long as you don't want too dramatic of a drop. I know Tein advertises them as something like a 2.2" drop but I say that is simply not the case, it's more like 1.7" I'd estimate. My GCs were down 2.75" and the Stechs are nowhere near the drop of the GCs, a full inch difference approximately, rather than the 1/2" difference you'd get by just looking at the supposed drop numbers.
Originally Posted by MDeezy
I had plenty travel with the S-techs. Fronts had lots of travel, and with Ben's mounts in the rear, had no problems?
I haven't bottomed out this setup once and it is more than enough handling for the street.
The only time the D2s really shined for me (over the Teins) was high-speed stability, which is awesome, but I don't need that right now.
Believe me, I know in great detail what I have lost/gain in changing setups. For whatever reason I don't imagine it being my last, but for the time being I really like it.
As far as AGX vs. Illumina I haven't been able to compare side by side but my ride is firm while not being jarring. It is very similar to the settings (half stiff) I used to run on my coilovers.
No, but i'm on sprint/AGX and hit the bumpstops from time to time. Aren't the front drops similar between the two? How are you sure you've never hit the stops?
The S-techs have a lower drop but a softer spring rate than the sprint, so the ride will be smoother and the springs will allow for more travel than a stiffer spring.
Originally Posted by Bonka
I've only bottomed out once or twice from going over a road patch I didn't see in time.
S-Tech's are not that low the CMS springs are lower.
a canuk with canuk springs
Front drop on a sprint I believe is 1.7 vs S-tech's 2.2.
There's no way the S-techs are a 2.2" drop man. I know they advertise it as such but it's simply not the case. They are more like 1.7ish. If it were warmer or at least less snowy outside I'd go measure it, as I have a stock maxima and a maxima with Stechs parked next to eachother outside.
Front drop on a sprint I believe is 1.7 vs S-tech's 2.2. Hitting the bump stops is a very distictive feeling, I never hit it, but I've felt the bump stop when I installed them and hitting that stiff bump. . . you'd have to notice it.
I think you're mistaken. The sprint front drop is at least 2".
Suspension travel has nothing to do with how stiff a spring is. Furthermore, a low, soft spring is the worst combination there is.
Well the Sprints could be 2" I dont know for sure but I always here it was pretty much the same drop as the S-tech.I was saying the S-techs are softer springs by comparison to the sprint srings. But it would be a bad combination to have a very soft spring and a very low drop, bad combination. I found the S-techs to be good and stiff enough to handle most of whats out there.
Dont get me wrong, I know they arent the best springs out there, but I considered it a good purchase.
Also if the spring rate is softer it would allow for the spring to compress/decompress more correct? If this being true then why would it not allow more susension travel if it will give more (compres/decompress) than another spring that wont give as much?
Explaing the harsher (so I've heard) ride with the sprints over S-techs.
A stiffer spring will have a tendency to limit the up and down motion, yes, but this is to your advantage to keep you off the bumpstops on severe bumps. Even so, the only thing that changes suspension travel is the ride height.
I feel the S-tech accomplish this, soft for a decent ride, stiff enough to give a semi-sporty feel, and keep you off the bumpstops.
however, autos will get a greater drop
I've been riding that setup for awhile now, on 18" chromes. The ride is harsh on bad roads, but when the ride is smooth you don't even realize your lowered. I know that sounds almost stupid considering any car rides nicer on good roads, but it is a big difference, and i'm sure on smaller wheels/thicker tires that would change. Day to day, it's not that bad, and the look makes up for it. Although i've only experienced stock and my current setup.
they were a bit harsh but very liveable. i've never had the s-techs but have read that they are ride a bit higher than the sprints. i only hit the bumbstops a few times, really only when driving over a really nasty pothole pretty fast.
good struts are a must. the AGX are great, i had them for quite some time. i've got illuminas and maxspeeds now and am loving the smoother ride, but there's a bit more dive when i'm really pushing it.
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
