ATF fluid in a 5speed?
Old Dec 17, 2005 | 02:22 PM
NewEngSurf's Avatar
I was wondering if puttin automatic transmission fluid in my 98 would help it out. I only say this because i hear that new atf fluid is automatic and manuel transmission friendly. My 98 is a 5 speed and has 104k but it doesnt shift into second or third smoothly. ATF fluid is thiner so i thought it might help it shift. Wut do u guys think or am i crazy?
Old Dec 17, 2005 | 02:26 PM
Fr33way™'s Avatar
Wild for Width
Fluids and Lubricants section...
I know that some Toyotas are interchangible but I do not think Nissan is.
You can try redline MT90 to help your problem.
Old Dec 17, 2005 | 03:51 PM
njmaxseltd's Avatar
Either your clutch is dragging slightly or your synchros are shot.
You can't use ATF in your 5 speed tranny.
Old Dec 17, 2005 | 06:23 PM
Gold5sd96maxima's Avatar
Gear Oil
LUCUS SYNTHEIC80/90 Gear Oil For Any Of Our Years
Old Dec 17, 2005 | 07:27 PM
MaximaSE96's Avatar
Maxima Owner
ATF in 5spd = BAD STUFF ABOUT TO HAPPEN
Old Dec 17, 2005 | 07:31 PM
nismology's Avatar
Says who? BMW has been using ATF in their manual transmissions for years. Can you tell us all exactly why putting ATF in a 5-speed is bad or is your post based on an assumption or hearsay?
Old Dec 17, 2005 | 08:15 PM
MaximaSE96's Avatar
Maxima Owner
because thats BMW...thats the way their manual gearboxes were designed...ours were designed to run with gear oil.....i kow other companies use atf as well and some use gear oils....and they obviously do it for a reason...so go ahead put ATF in ur Nissan Maxima 5spd and come them come posting saying ..."Problems with my 5spd Please Help"...then i ask did u put ATF in it...u say yes ...i say TOLD YA SO.....now i am not trying to be a di(k...but if the owners manual says use MT90 or whatever i forget the exact wording USE IT....and besides when i had my rebuild done on my 91 5spd the tranny place said use gear oil and not ATF because it will ruin the tranny because it wasnt designed to use ATF
Old Dec 17, 2005 | 08:40 PM
nismology's Avatar
You're still assuming things and passing them off as fact. And i'm pretty sure the owners manual says nothing about MT-90 since it's a type of gear oil made by Redline.
Old Dec 17, 2005 | 11:21 PM
the_3d_man's Avatar
i've actually heard that putting water in the transmission improves shifter feel .. cause it's thinner ... you know...
Old Dec 18, 2005 | 06:35 AM
njmaxseltd's Avatar
Owners manual says......
"Manual transmission grear oil API GL-4, Viscosity SAE 80W-90 only"
BMW fluids are quite different then most other cars on the road. They use lifetime fluids in their transmissions. They require no maintenance, my automatic E46 doesn't even have a dip stick. They are designed completely different then our Nissans.
FYI - Some BMW info.
Oil changes - every 15,000 miles, the thing holds 10 quarts.
Auto tranny - maintenance free, lifetime fluid. No dip stick, no drain, the unit is sealed.
Power steering - lifetime fluid
Rear Diff - 100,000 mile service, lifetime fluid, just check the level.
Fuel Filter - 100,000 miles, the fuel pressure regulator is built into the filter
General tune up - 100,000 miles
There is no PCV system, the BMW engine runs with a vacuum drawn on the crank case. If the engine develops an oil leak, it doesn't idle right because the crank case wount hold a vacuum while it's running. The BMW is a very interesting machine to own. The drivetrane is engineered quite differently then most cars on the road.
Old Dec 18, 2005 | 08:30 AM
MaximaSE96's Avatar
Maxima Owner
i also said i didnt know the wxact wording of the owners manual....i jusr had MT-90 in my head because someone mentioned it
Old Dec 18, 2005 | 09:25 AM
nismology's Avatar
What i meant was the owner's manual says nothing about MT-90 specifically. Surely you understood that.
Understood. But no one has explained explicitly why ATF is bad for OUR 5-speeds. All im hearing is "i think so" or "i heard so".
Old Dec 18, 2005 | 12:07 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
Nissan would not specify GL4 only if that wasn't what it requires.
Old Dec 18, 2005 | 12:47 PM
DennisMik's Avatar
as MaximaSE96 said, the nissan transmission is designed for the thicker 90 weight oil. this means that the clearances between the parts are bigger in order to allow the thicker oil to get inbetween the pieces. oil adds a cushioning effect. a lot of people know that if you have worn parts, put in a thicker oil. putting ATF into a nissan tranny will not fill the clearances sufficiently and the transmission would be operating with a lot of loose play in it as if there was lots and lots of wear.
Old Dec 18, 2005 | 01:15 PM
nismology's Avatar
http://forums.maxima.org/showthread....ght=ATF+manual
Just stirrin' the pot here...
Old Dec 18, 2005 | 04:33 PM
MaximaSE96's Avatar
Maxima Owner
but again thats the 6 speed transmission...its internally totally different than our 5 spds...designed differently...and who knows how long that tranny will last using ATF...sure if it may be smoother and easier to shift but it doesnt mean over a extended amount of time it wont cause it harm...obviously ATF has lubricating abilities so u wont notice it right away but give it time
Old Dec 18, 2005 | 05:43 PM
nismology's Avatar
The fact that the transmissions are different (clearly) is irrelevant because the 6-speed tranny calls for GL-4 fluid too.
And ATF causes harm to which parts of the transmission exactly?
Old Dec 18, 2005 | 07:46 PM
MaximaSE96's Avatar
Maxima Owner
ok good point...its still not proven that it wont harm ur tranny.....maybe i was wrong in saying it would be bad things to happen....but i would rather say that then say SURE ITS GREAT....then he comes back in 6 months needing a rebuild....i am just saying in my opinion with a mechanical engineering backround i dont see it being the best thing for the car...sure it will feel good at first with smooth shifting but in the long haul i dont think it will last
Old Dec 19, 2005 | 08:13 AM
nismology's Avatar
My point is this...instead of people saying "it's gonna trash your tranny" you all should be saying "let's see what happens" because there is no proof of the long-term effects of ATF in a manual tranny either way.
Old Dec 19, 2005 | 09:25 AM
Stephen Max's Avatar
Let's use a little logic and some facts to draw some conclusions.
ATF is a very good lubricant, otherwise it wouldn't be used in auto trannies. It is less viscous than gear oil so that it can easily travel through the small passageways and channels in the valve body.
Therefore, ATF will work in a manual transmission simply because it will indeed lubricate the gears and bearings under normal circumstances, and the lowered viscosity will reduce drivetrain losses.
However, it may not be the optimal viscosity for smooth shifting, and under severe loading and elevated temperatures the viscosity may not be sufficient to prevent surface to surface contact at the gear teeth. This is not as bad as it may sound, though, because there is very little sliding contact at gear teeth interfaces (if the gear teeth have been cut as involute surfaces).
Old Dec 19, 2005 | 09:51 AM
MaximaSE96's Avatar
Maxima Owner
like i said before maybe i was wrong in simply stating Bad things would happen....but again i dont want to go off saying sure it wont hurt it.....hell ill be a guinea pig if one of u wants to buy me a brand new tranny if/when my would blow up.....simply stated....just use what the Engineers and designers say to use in the owners manual...to me in my opinion its ur safest bet.....and again i have been proven wrong in the past and i wont have a problem admitting it
Old Dec 19, 2005 | 11:46 AM
nismology's Avatar
Isn't the coefficient of friction that the fluid allows for more important to smooth gear engagement than the viscosity? Redline MT-90's claim to fame for it's smooth shifting is that it allows for just the right amount of friction for smooth synchro engagement. It also uses this reasoning to dismiss motor oil as an appropriate gear lubricant. Not because of it's lower viscosity, but because it's just too slippery to allow the synchros to mesh properly.
+1 to everything else.
Old Dec 19, 2005 | 11:59 AM
tavarish's Avatar
fwd gone rwd cr00
hmm.....why not put ATF in your motor?
Use gear oil for manual trannies, and ATF for autos. There's absolutely no reason to do otherwise. I'm speaking only for maximas, as other cars have different fluid ('87 hondas have motor oil in their trannies, etc.)
-Freddy
Old Dec 19, 2005 | 12:03 PM
nismology's Avatar
-Freddy
Your post is invalid. If you can't say exactly why ATF is bad for our transmissions please don't post.
Old Dec 19, 2005 | 12:35 PM
tavarish's Avatar
fwd gone rwd cr00
then let's start an initiative, If you want to be the first to put ATF in your tranny, go ahead. Tell us the effects in 6 months.
The Nissan manual tells me to use gear oil ONLY, thats what I use, just like using Dexron-III in the auto trannies.
-Freddy
Old Dec 19, 2005 | 12:38 PM
nismology's Avatar
-Freddy
Thing is, someone has already tried it. A prominent member at that...
See post #15...
Old Dec 19, 2005 | 12:57 PM
Cutler's Avatar
Please sell your car......
Old Dec 19, 2005 | 01:28 PM
MaximaSE96's Avatar
Maxima Owner
See post #15...
again after 3 posts no else has responded to it....
Old Dec 19, 2005 | 01:31 PM
Cutler's Avatar
same weight as the stock oil, just better ingredients. You lose....
Old Dec 19, 2005 | 03:06 PM
nismology's Avatar
I was saying the owner's manual says nothing about Redline MT-90 specifically the same way it doesn't recommend Mobil 1 or Castrol GTX. If you'd read the post i quoted you would understand the context. Nice try...
Old Dec 19, 2005 | 03:09 PM
nismology's Avatar
Notice how old that thread is? And what does the fact that there have only been 3 replies prove?
Old Dec 19, 2005 | 03:10 PM
Jeff92se's Avatar
I'm needing a caw
That the tranny blew up and he's not telling?
Old Dec 19, 2005 | 03:18 PM
nismology's Avatar
asldkfjasldfk(*(!@*&!(@*!@!@#&#^%
Old Dec 19, 2005 | 04:43 PM
the_3d_man's Avatar
This thread, for some reasons, has sparked a lot of argument... but seriously... is anyone here actually considering running ATF in their manual? Cause that just sounds stupid... it's way too thin... and the transmission is designed to run thicker oil that will coat the gears and protect them (synchros in particular need the thicker oil)
So let the arguing continue I guess...
Old Dec 19, 2005 | 04:58 PM
MaximumCore's Avatar
Just to throw a possible answer to this question I have heard a totally different reason of why NOT to run ATF in your 5-spd and it doesnt concern weight of the lubrication. One of my fellow friends said that most 5-spd trannies that use gear oil have softer metals in the tranny and using ATF will act corrosive and kill the life of your tranny. So you may have a better lube feel but the side effect is that your tranny is slowly corriding inside. I honesty don't know if this is true but its just something I have been told by an insightful friend........Thanks
Old Dec 19, 2005 | 05:30 PM
MaximaSE96's Avatar
Maxima Owner
Another good point......i didnt think of that....Nismology i am not trying to be a A.ss to you really...but i ahve to say again GL-4 is obviously used for a reason
Old Dec 19, 2005 | 05:41 PM
nismology's Avatar
I'm just playing the devil's advocate. When it comes to things like this, it's not enough to just say "i heard this" or "i think that". I just wanted to hear some reasoning.
Old Dec 19, 2005 | 05:47 PM
NewEngSurf's Avatar
Look at what I started
I dont plan on putting ATF in my tranny, just a thought, i mean if it was better to be running atf in manual transmissions then there would be no such thing as gear oil. Anyway, im gona drain my fluid and add some fresh gear oil and see if my shifting is any smoother
Old Dec 19, 2005 | 09:47 PM
tavarish's Avatar
fwd gone rwd cr00
ok, if no one is going to try this in their 4TH GEN 5 SPD, then I can consider their case closed. Unless someone has results, anything anyone says is pure speculation. I say leave the fluids to their intended purposes. ATF Dexron-III for auto trannies, GL-4 gear oil for manual trannies. If it ain't broke, don't fix it.
Old Dec 20, 2005 | 05:28 AM
-Freddy
It is not uncommon for people to put a quart of ATF in their crankcase. It has a much higher detergent content than motor oil and can clean out a gunked up engine pretty effectively. The reason you don't want to run only ATF in your engine is because it can't handle high engine temperatures as well as engine oil. Manual trannies run at much cooler temps, though.
There's a lot of people in this thread that are saying just don't do it without giving a reason why (I guess because they don't know why). Point taken, but it is educational to talk about exactly why you shouldn't do it, and under what circumstances it might be okay.
