ATF fluid in a 5speed?
#41
Originally Posted by Stephen Max
It is not uncommon for people to put a quart of ATF in their crankcase. It has a much higher detergent content than motor oil and can clean out a gunked up engine pretty effectively. The reason you don't want to run only ATF in your engine is because it can't handle high engine temperatures as well as engine oil. Manual trannies run at much cooler temps, though.
There's a lot of people in this thread that are saying just don't do it without giving a reason why (I guess because they don't know why). Point taken, but it is educational to talk about exactly why you shouldn't do it, and under what circumstances it might be okay.
Thanks,
-Freddy
#42
#44
Originally Posted by MaximaSE96
but u also cant go off and say go ahead and do it it will work fine
I'd be amazed if you could find a post of mine that even came close to suggesting it was completely okay.
#46
i never said that anyone in particular said that....but ur arguments seem to suggest that is no problem with it....atleast the way i interpret them
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
MaxRPM6
09-11-2015 06:56 PM
