Budget bees in the can???
i just installed my budget y pipe about 2 weeks ago, and noticed that when i really step on it, the dreaded bees in the can noise is there...i thought budget wasnt supposed to have that.....thats part of the reason y i bought this one....any ideas of what may cause this sound?
yeah, loose connections. are you using their testpipe, too? because i used their test pipe and experienced Bee's, but changing back to stock cat converter totally eliminated that problem.
then you'll have to wrap it up, but you'll still get a slight hint of the bee's. other than that, get a loud-azz exhaust to cover up the bee's sound, or turn up the radio, or stick some earplugs in your ears, or...patch it up anyway you can!
I have the same problem just never posted about it. It only happens when I rev to about 3k. Idle is fine. I just figured it was a leak somewhere just have gotten around to fixing it. I have sound clips of it if anyone wants to hear what it sounds like.
I've had my y-pipe wrapped for a couple of years now. The header wrap greatly reduced the bee sound on my car. Just rewrapped it a couples months back, pipe looked good.
Ok here is the link. Before anybody says anything I know the video sucks and its short. Its supposed to be much longer but it wont upload the whole video for some reason. You can really hear at the begining it sounds like a 1960's beetle or something. http://media.putfile.com/Anoyying-metallic-sound
Originally Posted by Wheelie King
I'm consdering a Y-pipe and I'd like to know the benefit/risk.
Thanks.
A noticeable increase in power, no risk that I know of. Great bang for the buck mod, read the stickies for more info or this link (http://maxmods.dyndns.org/index.php?MaximaYpipes).
It means that the two y pieces are not the same length so they resonate sound. It is normal. BUT then again as everyone else and their sister has said, check to make sure the pipe is on tight and that your flex is good to minimize the effect.
i really dont know if there are any gains yet...since it turns out my knock sensor is bad...will let ya know tho......
thanks for the advice guys
the shop that put it on checked all the bolts and they are all fine. he said that sound is actually fireballs going through youre exhaust pipe? sounds kinda crazy to me
he also said once the carbon builds up inside the y pipe that the sound will go away after a while, but we will see.
Originally Posted by konak85
whats that supposed to mean? Is it normal?
God damn bees in the can posts. Your exhaust is not gonna sound the same with a y-pipe as it did stock nor is gonna sound like a mustang. Your gonna get a little odd noise here or there. The pipes are not equal length, thus the exhaust waves will hit each other. The whole bees in the can term started like 5-6 years ago and now anytime a member with a y-pipe gets a slightly odd noise they make a bees in the can post.
AMEN....same thing with the "I put aftermarket cat-back system on my car..i get wierd rumbles at idle" threads
well geez im sorry, i just read that budget y pipes didnt have that sound, so thats y i got it and for some reason it makes that sound so im like wtf
thanks to those that were nice enough to help though
Some people just call it "bees in the can" eventhough the sound is different just because they saw the terminology in the board. Can you describe the actual sound more instead of just rumbles? What is the sound difference between when its idling and at WOT?
Dog On bees in the can posts. Your exhaust is not gonna sound the same with a y-pipe as it did stock nor is gonna sound like a mustang. Your gonna get a little odd noise here or there. The pipes are not equal length, thus the exhaust waves will hit each other. The whole bees in the can term started like 5-6 years ago and now anytime a member with a y-pipe gets a slightly odd noise they make a bees in the can post.
yeah, only way around it is headers, someone must have got the pipes mixed up when they called the ypipe a ypipe, its should be called Bee-pipe and then the bpipe should be the WHYpipe, so you can ask yourself, Y does my exhaust sound like BEES IN A CAN ?
Or maybe thats why we call it a WHY pipe ? So we can wonder Y my exhaust sounds like bees in a can ?
My maxima sounded like a dump truck with a ypipe at cruising speeds, and was much worse than bees in a can
at wot !maybe try stock bpipe and muffler if you want to quiet it down and if you are running stock bpipe now then , no idea !
at least you have a faster max even with the buzz !
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Max_Vader_2K
Jun 2, 2001 12:55 PM
Max_Vader_2K
Apr 25, 2001 07:16 AM
