Need help, Idler pully and belts replaced, Squeel and hissing sound now
The bearings on my idler pully were shot so I had my mechanic friend replace the idler pully and the two belts (accessory and PS).
Anyway at start up its been squeeling and when dirving and accelerating I hear a hissing sound.
I called my friend and he said he set the belt tensioner a little tight so the belt could strecth and this could be causeing the sounds and for me to drive it for a couple days and then bring it in if still making the noise. Does this sound plausible or am I getting the run around because he doesnt wanna do it right?
Check the tension after a couple of days. Than you want to tighten the tension nut a half a turn or so. This should get rid of the squeeling on car start up. Do you know what type of belts he put in. I.e Gator belts??
I'm not sure thebrand of belt used other than the fact they werent OEM, but I did recognize the Aftermarket label (It had the word car in it I believe, blue and a little red package).
So when I take it back to him for my Differential seal he can crank the pully and fix this up pretty easy?
I JUST got a ypipe and KNock sensor with a tune up done (newly bought Max) and I LOVE the sound but this hissing pisses me off and keeps me from really enjoying it because I keep thinking it sounds like the belt is rubbing and is gonna snap on me (I know this is outlandish, but this is the mind of a newb wanna-be mechanic)
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
