stupid cali spec car
Old Jan 18, 2006 | 05:42 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
im so peeved i should have checked the vin....ordered a fed spec ypipe cat combo on ebay from warpspeed and the cars a cali spec i cant believe it. i mean youd think that a maxima that was built and delivered to newyork in 1999 and mind you it was actually built june 98 would be a fed spec car danggit i wanted a fed spec maxima. why the heck does california have to be different i hope they fall in the pacific.................vent over...........sry had to vent a bit i was just shocked when i saw the "v" in the 12 spot on the passenger vin plate..........
Old Jan 18, 2006 | 06:39 PM
njmodi's Avatar
Do I get a tax break?
I'll take the cat-back off your hands if it's just taking up space at your place
(sorry to hear about your plight)
Old Jan 18, 2006 | 07:07 PM
YoU CaNt SeE mE
wasnt a cat back it was a y pipe with a cat. hopefully i can return it and get a cali spec....
Old Jan 18, 2006 | 07:14 PM
M_oz. 555's Avatar
Are you 100% sure that it is cali-spec? When I ordered my y-pipe last year I ran into the same thing. According to my VIN i have a cali-spec car but when I talked to Custom Enterprise they told me that some are not and it turns out mine isn't. The way to check is to look at the number of wire harnesses between the radiator and engine. If there are 4, then you have a cali-spec, if there are 2 then it is fed-spec. I lost the link that showed a picture of it, but if you want further clarification call CE.
Old Jan 18, 2006 | 08:02 PM
YoU CaNt SeE mE
humm ill check that out its driving me nuts ill go to the car now and look....wheres my flashlight ? LOL
Old Jan 18, 2006 | 08:09 PM
njmodi's Avatar
The 4 harnesses correspond to 4 O2 sensors (just an FYI).
Old Jan 18, 2006 | 08:16 PM
YoU CaNt SeE mE
well i have all 4 sensors in front friggin@^%#@&#^%@&*$. wish i knew that when i bought it. but all well next time i nkow what to look for. all runs well right now no CEL or harsh idle. so ill let it be for now. now i have to hope warpspeed diddnt ship the fed spec pipe yet. if not ill have to mail it back on my penny. all well. so performance wise are these worse than the fed specs ? if i put on a true CAI so i need a special one or does that only apply to the exhaust.....ive got a CAI on the way its the same as the injen but its off ebay (no fender cutting it goes between engine and batt. thanks
Old Jan 18, 2006 | 08:38 PM
whlimi's Avatar
Couldnt you get an exhaust manifold from like a 98 fed spec and replace the exhaust manifold with the precat on your car...and then use the fed spec y-pipe...is this possible guys? Just throwing out some ideas...
Old Jan 18, 2006 | 08:39 PM
BigLou93SE's Avatar
The reason why you could use a fed-spec y-pipe on your 97 cali-spec Maxima is because the y-pipes for the years between 95-98 are the same reguardless of emissions standards. The 99 calispec is very different from the rest of the y-pipes.
Old Jan 18, 2006 | 08:43 PM
ti2tmax's Avatar
Has his VINs memorized
Don't feel too bad about it, I own a 99 Cali spec car, and I live in Maine, the furthest state(continental) away from California!! And the one with about the least concern about smog and emissions!
Old Jan 19, 2006 | 02:49 AM
coso's Avatar
i own a 99' cali spec, i already have Y pipe from Warpspeed installed and its very different from the above years... but the other day i was wondering if its possible to remove or eliminate the front manifold pre-cat, thanks in advance
Old Jan 19, 2006 | 02:53 AM
Turiman's Avatar
The last post was me, but i was in other computer (at coso's house)
Old Jan 19, 2006 | 07:38 AM
1FSTMAX's Avatar
I have a cali spec maxima with a fed spec y pipe...
i took off the front precat off, and replaced it with a fed spec front manifold.
Old Jan 19, 2006 | 10:56 AM
Turiman's Avatar
oh so that can be done, but if that were the case, what about the o2 sensor? does fed spec has an o2 plug?
BTW thanks for the fast feedback
Old Jan 20, 2006 | 08:01 AM
1FSTMAX's Avatar
the fed spec y pipe has two o2 bungs for the primary o2. I just added an O2 simulator to the two remaining downstream o2. Pretty easy conversion.
Lakersallday24
Jun 16, 2019 01:35 AM
Supragte
Aug 12, 2015 10:00 PM
Team STILLEN
Aug 10, 2015 04:29 PM
1992maximase30
Aug 5, 2015 09:27 PM
