Nissan factory OEM clutch disc made by Exedy
It is well known that Exedy makes factory clutches for most of the import car manufacturers as well as some of the domestics. But usually when a company is name branding their goods for use by an oem, they do not put their own name on as well.
Here is a picture of a clutch disc I just received from Pinnacle Nissan.
Sorry if this is a repost, but up until now the only name I have ever seen on a Nissan clutch disc has been Unisia.
Originally Posted by southeast_first
weird, i always thought our oem clutches were made by valeo.
Originally Posted by KRRZ350
They are, and apparantly the 5th gen. must be made by exedy, interesting.
5th gen clutch disc p/ns (by prod. date)
April 99 - Oct 2000 - 30100-2Y904
Nov 2000 - June 2001 - 30100-2Y920 (Exedy unit pictured above)
5th gen pressure plate p/ns (by prod date)
April 99 - Oct 2000 - 30210-89F00 - 635 kg clamp force
Nov 2000 - June 2001 - 30210-2Y920 - 750 kg clamp force
The 5.5 gen (VQ35) also use a 750kg pressure plate but the clutch disc diameter was bumped up to 250mm from the 240mm that was used from 95 thru 01.
Hey Southeast First, How did you get your grill like that? did you paint the side chrome bars and left the nissan emblem or is that a special kind of grill?
ok so 30100-2y920 is the correct number for the clutch disk? i want to do the 5th gen. setup on mine. what are the correct numbers. i have this:
release bearing:30502-41u20
clutch disk:30100-2y920
clutch cover/pressure plate:30210-89f00
I emailed DAVEB about 30210-2Y920 and he said it was smaller in diameter and he recommended the former one instead.
It wouldn't make sense for Nissan to use mismatched sizes so I figured it was an error. I ordered the 30100-2y920 disc and it matches up perfectly with the 30210-2y920 pressure plate.
MaximaDrvr
Aug 19, 2015 08:20 PM
KGMtech
Aug 18, 2015 09:21 AM
