pressing ball joint on car?
I just diagnosed my minor vibration in the steering wheel to a bad ball joint. I am going to be replacing it tomarrow and in the FSM I see that they move the axle and strut assembly out of the way. Is this the best was to do this? Should I just drop the control arm and press it in outside the car?
And yes, I know that swapping all the bushings is a good thing to do but I am keeping the work minor until we get to the warmer months. Thanks for any help guys.
I don't think you'll be able to do it on the car (unless you have a portable lift?)...
It's easiest to drop the LCA, press the old one out, new one in and put things back together.
Can you not rent the tool to remove and press in a new ball joint from Autozone? I was under the impression you could.
I want to keep the cost minimal, thus I am replacing only the ball-joint.
I think the tool needed to press in and out, only most shops would have.
Maybe check with some local shops and see how much they'd charge to press in a new ball joint. If you total cost of the whole work should exceed $70, it would be better to get a new control arm that would already have a new ball joint on it.
I have a driver side in my room waiting to go on, and maan. . . I tell you that ball joint is stiff! Should restore a smooth ride. Replacing the bushings (swaybar end link etc) should reduce vibrations and restore a smooth ride .
edit: a 22mm socket socket + 3' break bar +wd-40 made taking off the control arm very easy.
I don't get what the big deal is. I changed the RF lower on my '98 a couple months ago. I have a BJ press, but most auto stores will loan them for free. It took less than an hour to change it on the car. I recall it being a bit of a challenge to get the nut off, but nothing terrible. It was like $35 for the joint.
Given that it's much easier to just replace the entire LCA than the ball-joint and bushings seperately and that there is no significant cost difference (of entire LCA, vs. ball joint + bushings replacement, it seems to make more sense to replace the LCA.
I am in the process of dropping the control arm and I need to get the threaded portion of the ball joint out of the steering knuckle.
I saw that a pickle fork is used, I am without a car for now so is that tool essential or can I get it out of the knuckle with something else.
This just came up recently - I think MDeezy had a heck of a time breaking his free.
A pickle fork won't work (well, it most likely won't work, not enough leverage and you'll tear up the ball joint boot for sure).
Dave
Originally Posted by dgeesaman
If you remove the arm from the car you should plan on getting an alignment.
Dave
Dave
(I agree, btw, just waiting for the regular yes/no/yes/no discussion that will ensue).
Ok I dropped the control arm awhile ago but I cannot figure out which tool (Advance Loaner kit) and how to use it to pull the ball joint.
BTW I did this with the strut/axle still attatched and YES I will be getting an alignment, I have a lifetime so that's a no brainer.
Any tips on how to use the puller to get this ball joint out? I am going to try and work on it some tomarrow morning before I take it somewhere to get it pulled/new one pressed in.
Thanks.
Thanks.
I used this tool:
http://www.harborfreight.com/cpi/cta...emnumber=38335
1) Remove the snap ring
2) Use the sleeves and plates to push out the ball joint. You need a big sleeve on the receiver side, and a smaller sleeve on the pushing side. A plate fits between the sleeve and the clamp on each end.
Dave
Dave
Fr33way, how did you know you ball joint was bad? I replaced my bearing yesterday and I had trouble tightening the ball join back down. The stud inside the ball joint would just spin. I eventually got it back on with an impact gun. The guy at Advance told me it is bad but i'm not sure if he really knows what he is talking about.
Originally Posted by njmodi
oh oh... not this again
Thanks.
Thanks.
Pickle fork was of zero help except destroying my ball joint bushing.
Alright guys I've got the summary.
dropped the control arm using the pickle fork method
took to a local machine shop, had them pull/press the new one in ($10)
installed earlier today and all is well, hope to get aligned early next week
Total Cost: a hair (with tax) over $40
When I knew the right wheel I then just looked at all the bushings and stuff while I did the wiggle from the inside and there was obvious play in the joint.
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
