M/T Flywheel Bolts VS A/T Flywheel Bolts
Old Jan 25, 2006 | 09:17 AM
s0ber's Avatar
Anyone know whats the difference? I know there the same exact thread, of course, but is it a length difference or what the hell?
Old Jan 25, 2006 | 09:26 AM
Jeff92se's Avatar
I'm needing a caw
Different lenghts. MT versions are longer I think. Do NOT interchange them!
Old Jan 25, 2006 | 09:29 AM
s0ber's Avatar
I have a few MT ones here, they look tiny.... :\
Old Jan 25, 2006 | 09:37 AM
s0ber's Avatar
Is it possible to use A/T bolts on the M/T?
Old Jan 25, 2006 | 09:55 AM
cardana24's Avatar
Blown
they are diffrent sizes for sure. I had to take an auto flywheel off before I put the manual flywheel on my motor. I would not want to take the chance of the auto bolts running too deep...thats just me. But I am positive they are different lengenths.
Old Jan 25, 2006 | 02:19 PM
abci30's Avatar
oh noes!!!!1111
the part number for the M/T flywheel has changed. When i got mine for a swap the bolts that came with it were the exact same size as the auto ones. I'm thinking they did this so they would not have to carry 2 sets of flywheel bolts. So depending on which flywheel you have you the a/t and m/t bolts may be the same. IIRC the auto ones are shorter than the M/T ones
Old Jan 25, 2006 | 02:23 PM
Kevlo911's Avatar
Kevlo for President
My manual swap SHOULD be comming soon, but my flywheel might be mounted on a different crank
Old Jan 25, 2006 | 02:59 PM
s0ber's Avatar
3.5? I30??
Old Jan 25, 2006 | 06:35 PM
Germr497SE's Avatar
Auto Flywheel ?
i think auto cars dont have a (flywheel) they have tq converter... may be Im wrong duh.....
Old Jan 25, 2006 | 06:41 PM
s0ber's Avatar
They have a flexplate, basically a flywheel without the friction rotor thing on it.. and 4 bolts to bolt onto the torque conv...
Old Jan 26, 2006 | 08:18 AM
s0ber's Avatar
Well I have finally got some M/T bolts and took a pic of both...
The length doesnt look like that much of a big deal..
Old Jan 26, 2006 | 08:58 AM
juani's Avatar
Rockin' VK56!!
I think I used AT flywheel bolts to bolt on manual flywheel when I did the swap. I have to check the left over bolts from swap in my garage, but till today(more than 8 months) it runs fine.
jeff92se: any reason why I shouldn't use AT flywheel bolts? Can it become lose?
Old Jan 26, 2006 | 09:04 AM
Stephen Max's Avatar
The engineering rule of thumb (actually there is a scientific reason behind it) is that as long as you can get three threads fully engaged, you will be able to develop full tightening torque in the bolt. The AT bolts are long enough based on this criterion.
Old Jan 26, 2006 | 09:13 AM
Jeff92se's Avatar
I'm needing a caw
Stephan. I thought it was more like 8 threads? Sober. Put one of those auto bolts though the flywheel and see how many threads stick though the other side Then decide if you want that little # of threads holding a 22lb steel mass turning 6,000 rpm right under your right side nad
Old Jan 26, 2006 | 09:16 AM
Kevlo911's Avatar
Kevlo for President
Better safe than sorry....
Old Jan 26, 2006 | 09:27 AM
s0ber's Avatar
lol thats pretty convincing.. me =
Old Jan 26, 2006 | 09:37 AM
J.E. Shigley, Mechanical Engineering Design, Third Edition, page 252:
"It is interesting to know that three full threads are all that are required to develop the full bolt strength."
The flywheel spin loads act normal to the bolt axis, so no spin loads are imparted to the bolts. Bending moments are avoided by the hole clearance so that the expanding flywheel does not react against the bolts.
Old Jan 26, 2006 | 09:40 AM
Jeff92se's Avatar
I'm needing a caw
I just think there's a specific reason why Nissan designed at least 6-10 thread engagement for each bolt. Although the spinning might not create any signifcant loads, I'm sure the clutch and said parts add side loads and also vibrational loads from being bolted to the flywheel
Old Jan 26, 2006 | 11:47 AM
Yeah, I don't think anyone would design a threaded connection with only a three thread engagement, but you could if you wanted to. The strength and stiffness of a bolted connection isn't due to the bolts only, but in large part to the rigidity of a preloaded assembly. The preload is determined by the number of bolts and the bolt torque, and the torque in a bolt can be fully developed with only three threads.
Old Jan 26, 2006 | 11:50 AM
streetzlegend's Avatar
this swap is never gonna happen!!!! diaf
Old Jan 26, 2006 | 11:53 AM
s0ber's Avatar
Old Jan 26, 2006 | 11:57 AM
s0ber's Avatar
Alright I took some more pictures, here's the thread lengths on the A/T bolt... with and without the flywheel spacer thing w/e it is..
There is clearly more than 3 threads here..
Old Jan 26, 2006 | 12:08 PM
Jeff92se's Avatar
I'm needing a caw
w/ the 5-sp flywheel?
Old Jan 26, 2006 | 12:12 PM
s0ber's Avatar
yeah thats a 5spd flywheel
do any of you happen to know what the "flywheel reenforcement plate" thing there is for?
EDIT: According to FAST its there for the A/T flexplate, but I dont see it for the M/T?? Is it needed?
You can see it in the 1st pic above..
Old Jan 26, 2006 | 02:57 PM
abci30's Avatar
oh noes!!!!1111
i don't think my early post was clear. they changed the part number and design of the m/t flywheel recently. You will need to use that plate and you can use the A/T bolts since they are now the same. If you use the M/T(12315-77A00) bolts with the newer design flywheel with the plate you will not be able to tighten down the flywheel to the crank because the bolts are longer. IIRC Old flywheel part number is (123102y910) has thicker center and does not have that plate. New flywheel part number (123102y911) has to be used with the plate and the same bolts as the A/T flex plate. Sorry i don't know the part number but if you call the dealer and ask they will have it.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
