problem after tranny fluid switch
Old Feb 3, 2006 | 05:58 PM
xlcrew's Avatar
I’m Back
hey guys i just switched out my old tranny fluid in my 5 speed. i put in redline mt-90. the shifter feels really mushy in 3 and 4rth gear. the others feel fine. is this normal. i don't remeber it happening before when i did it about a year ago, the tranny has been rebuilt by the dealer since and they put in some crap tranny fluid. after only 10000 miles it was almost black. well i hope someone has an answer for me. thanks
Old Feb 4, 2006 | 09:19 AM
xlcrew's Avatar
I’m Back
no one has had this issue?
Old Feb 12, 2006 | 02:42 PM
mysticalpun's Avatar
I was kind of curious, because I just installed a new clutch in my 00 max a few days ago, and I cannot get the hydraulic clutch system bled properly! Also the gear case housing is leaking tranny fluid fluid, What should I do?
Old Feb 12, 2006 | 05:46 PM
97neptune's Avatar
sounds like you need a new clutch line. over time they get tiny pinholes and air gets in the system and fluid finds its way out. that may be where your fluid is leaking from and not the housing
Old Feb 13, 2006 | 08:39 AM
Max_Gator's Avatar
I know it is no help to you - but may be to others who read this post, you didn't need to bleed it. The clutch can be changed by just moving the piston that actuates the clutch - then move it back when you get done. That's how I did mine.
Old Feb 13, 2006 | 08:43 AM
Max_Gator's Avatar
As for the original question, MT 90 will make the shifts feel smoother but shouldn't make them feel "mushy." Did you do anything to shifter mechanism when you changed the fluid?
Old Feb 13, 2006 | 08:47 PM
xlcrew's Avatar
I’m Back
it seemed like the tranny moved around a little bit while i was getting the bolts loose. that might be it. i don't know
Old Feb 15, 2006 | 06:39 AM
getbigtony's Avatar
?? maybe mine feels a little mushy after i changed it last week. i used some pennzoil product. forget which one but it wasnt synthetic. feels a little mushy, but smoother to me. but when i asked someone to order it for me, they didnt order enough so i had to use some other hydraulic gear oil as well cuz the shop was closed. feels like my 1st gear synchro is going wack, but not that i use it that much. think im gonna drain it and fill it up again.
Old Feb 15, 2006 | 06:43 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Shoulda used AMSOIL...
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
TheMafia
Sep 4, 2015 08:26 AM
Lowered_a33
Sep 1, 2015 07:49 PM
