Advice needed!!! 2.62 pulley may be going on soon!!
Old Feb 7, 2006 | 02:21 PM
chris'smax's Avatar
Ok so here we go again. Today one of my freinds gave me a 2.62 pulley he had laying around and i was so excited that i didn't think about how that would cause a serious threat of detonation issues. I am still running stock timming w/ the water/alcohol injection. When running the 2.87 pulley with the w/a injection my boost guage only reads 10-10.5 psi and 12psi w/o it. I still have to do my cold air intake and 3 inch pipe. My question is will runing the 2.62 w/ the cai and the 3' pipe be to much w/ stock timming. I really don't want to hassle with the emanage timming harness but if it is needed i will go that route.
Btw when adjusting timming while tunning what device is used to detect detonation so that adjustments can be made?
Old Feb 7, 2006 | 08:56 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Definitely get the timing harness and pull some timing, especially since your Emanage is scaling the MAF voltage for bigger injectors.
Supposedly, reducing the MAF voltage advances timing by putting you in a lower load area of the timing map.
J&S Safeguard is the BEST option for tuning timing and saving your motor if things go wrong. You could also trade up to the EU, so the injector scaling wouldn't affect timing.
Old Feb 7, 2006 | 09:01 PM
chris'smax's Avatar
I am using the injector harness when adding fuel. I thought if you were adding fuel via maf conditioning is when the timming was advanced?
Old Feb 7, 2006 | 11:13 PM
jcy98maxse's Avatar
Turbo is too much fun!
I believe with the MAF when you pull fuel or - correction(on SAFC) is when timing is advanced. Adding fuel/ + correction can lead to timing retard, however the amount of retard will not be known without getting the timing read.
Old Feb 8, 2006 | 12:22 AM
mjk's Avatar
mjk
Head shot!!!
2.62, is that like 15psi??
Old Feb 8, 2006 | 07:57 AM
IceY2K1's Avatar
I could be wrong, it has been awhile, but the injector scaling is done through MAF conditioning.
Old Feb 8, 2006 | 09:55 AM
SPiG's Avatar
SomePsychoGuy
Go with the 2.62". FTW.
Old Feb 8, 2006 | 09:59 AM
IceY2K1's Avatar
The 2.62" pulley and running 100% methanol injection would be a good test on the dyno, since you'd be able to hear if there was detonation.
Old Feb 8, 2006 | 10:02 AM
Blu's Avatar
Blu
the tits
dyno with the 2.87 then post back.
Old Feb 8, 2006 | 04:26 PM
chris'smax's Avatar
yea this will not be going on for a couple of weeks. I am in school right now so i am just collecting stuff.
Old Feb 8, 2006 | 05:06 PM
Nealoc187's Avatar
SLOW
Yeah I think it is wiser to dyno or track your car to make sure it is making the power it should be first. You have already done a ton of mods. If your car is not making the power it is supposed to be, the more mods you do the harder it will be to troubleshoot.
Old Feb 8, 2006 | 05:23 PM
chris'smax's Avatar
yea i learned my lesson last time
Old Feb 10, 2006 | 01:52 PM
IceY2K1's Avatar
Buy the ignition harness yet? You'll need the diodes from BigDogJonxs' thread too.
smplyamzng
Dec 13, 2015 01:19 PM
kenc15
Sep 25, 2015 06:38 AM
TonyJr
Aug 20, 2015 12:14 AM
carlosvq30
Aug 17, 2015 11:32 AM
