MY AE MOD - pictures
Old Feb 7, 2006 | 04:02 PM
godlyone's Avatar
ahhh! cliMAX!
I used this write up:
http://www.cardomain.com/ride/2190617/3
The only things I need to add is
A - temperature - set it to like 225, its more than enough.
I only needed to put it in for 10 min, and they came apart very nicely
MAKE SURE TO PUT IT FACE UP. The write up says face down.. but it become hazy after that...
Original Front:
My left headlight was very hazy.. so i did the AE on it first.. because it wouldnt be as bad if the headlight got destroyed.
Originals:
Say goodbye to headlight # 1 [I was very scared doing this lol]
Headlight split into its parts - front, back and silver middle piece:
Using a cloth with water and soap.. I began the rubbing process:
godlyone's Avatar
ahhh! cliMAX!
After a lot of rubbing.. and I mean a lot! :
My headlights were very hazy.. so I did polishing:
They were really really hazy:
After polishing #2:
Right one:
Left one:
Old Feb 7, 2006 | 04:03 PM
godlyone's Avatar
ahhh! cliMAX!
Installed on car:
Also, to prevent the condensation I had before, I siliconed the whole border around both headlights:
Taking the headlights out of the car wasn't too bad.. maybe like 10 min for both.
Getting them in was a PITA.
Old Feb 7, 2006 | 04:06 PM
GBAUER's Avatar
Nice job, but I wouldn't have done the silicone. You'll never get them back apart now. FYI: heating and re-assembling them would have sealed them as good as the factory did.
Old Feb 7, 2006 | 04:15 PM
godlyone's Avatar
ahhh! cliMAX!
Well, as you can see in the original picture, the left one has a major amount of condensation. There was a leak somewhere.
The silicone is fairly easy to take off anyway.. you just use a knife and cut it off.
Old Feb 7, 2006 | 04:40 PM
Maximized2000's Avatar
Your lights look awesome and so does your car.
Glad to see my write-up helped. The only reason why I had the headlights in the oven twice was because I wanted to take my time prying the headlight apart. I didn't want to pop it apart with one shot..I was afraid of cracking something.
I placed the headlight in the oven face down on a wet towel because I didn't want the front plastic heated up. I didn't get the condensation in the headlight when I had it faced down.
Great Job!
Old Feb 7, 2006 | 04:43 PM
godlyone's Avatar
ahhh! cliMAX!
Thanks a lot man.
The condensation I had in the headlight prior to doing any work on them at all.
The factory seal was just crappy I guess.
The reason I advised keeping them up, is because the first light I did, I followed your directions, and put it face down. When I took it out, it was more hazy then when I put it in.
When I did the second one, I put it face up, and it did not change the haziness.
Old Feb 7, 2006 | 04:45 PM
Either way is fine..as long as you don't melt anything.
Old Feb 7, 2006 | 05:03 PM
ressling's Avatar
HOOSIER Daddy?
your car looks beautiful. very nicely done. way to work on the headlight using elbow grease. again man looks very professional
Old Feb 7, 2006 | 05:23 PM
Nomad's Avatar
Dang nice!!! Did you polished the inner side of the lense? I still have my stick light laying around. I've got to redo them since lenses are hazy.
Old Feb 7, 2006 | 05:27 PM
bigfatty's Avatar
Booyah grandma.... BOOYAH
When I did mine, I put mine face dwon with no troubles. Here is a side by side pic of one done and not done for comparison.
Fat
Old Feb 7, 2006 | 05:36 PM
godlyone's Avatar
ahhh! cliMAX!
Nope, just polished the outside...
I was thinking of doing the inside.. but since it was perfectly clear. The haze only forms on the outside.. because its exposed to the weather and other elements.
Thanks for the compliments.
Old Feb 7, 2006 | 06:30 PM
NOCturnalI30's Avatar
what did u use to polish it???
Old Feb 7, 2006 | 06:48 PM
godlyone's Avatar
ahhh! cliMAX!
I had some insane polish actually.
I found the polish that is used to make fiber optics maximally transparent.
It is not even rated in grit.. it just said "3 micron"
I belive that's about 2500grit
Used special polishing liquid which was also from the fiber optics thing.
Any plastic polisher should work. There is actually a how-to somewhere here.
Old Feb 7, 2006 | 08:09 PM
Gjohnson's Avatar
Looking good. I did mine a couple of weeks ago.
Old Feb 7, 2006 | 08:20 PM
kingofsorrow's Avatar
looks great. i really like how your lenses look after the polishing.
Old Feb 7, 2006 | 08:38 PM
ope2k4's Avatar
Nice mod. Im still waiting for the day I will have the guts to retrofit my ebay projectors
Old Feb 8, 2006 | 09:54 AM
Mizike's Avatar
Great job on the headlights.....to top it off you outta replace the amber bulb with a chrome bulb that lights up amber....keep up the good work!
Old Feb 8, 2006 | 10:05 AM
upstatemax's Avatar
Looks good, I used the same write-up. I used PlastX to take the chrome off though, much much easier.
When I had mine in the oven at 250 for 20 min they still would not come apart... I had to bump it to 275 for mine to come apart and they still did not come apart to easy.
Old Feb 8, 2006 | 10:10 AM
Lusty2Kmax's Avatar
Good job, looks nice. I was going to do the same with mine but instead went with a 02-03 front end.
Old Feb 8, 2006 | 12:26 PM
resurrectedmax's Avatar
enthuzed.........
nicely done. thinking about this seriously
Old Feb 8, 2006 | 01:23 PM
peachman's Avatar
Nice job!! looks awsome.
Old Feb 8, 2006 | 06:04 PM
BRINKLEY's Avatar
nice job and writeup, I did mine a couple months ago, its not as hard as it looks or sounds....
Old Feb 8, 2006 | 08:37 PM
housecor's Avatar
Great writeup and excellent pics of the process! Results look very clean.
Old Feb 9, 2006 | 06:19 AM
shift_2kmaxima's Avatar
godlyone ----- nice lower grill, where did u get it, how much was it? or did you make one ur self? i got upper one, but iam looking for lower, couldnt' find it on ebay....
thanks
btw nice headlights, i did the same mod, looks really good
thanks
huso
Old Feb 9, 2006 | 07:19 AM
shurik's Avatar
What's up bro!!!
Hey man what's up. I see that you live close to my area. I'm in Tulsa BTW.
Old Feb 9, 2006 | 09:46 AM
teamsinister's Avatar
Great job, looks good
bigfrank
Oct 1, 2015 12:51 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
