cALIPER BOLT HELP!!!!!!!!
Old Feb 7, 2006 | 06:10 PM
NOCturnalI30's Avatar
My bolts that hold my calipers are free. They wont come off WHAT THE HELL DO I DO???????????ANY ADVICE WILL BE APPRECIATED
Old Feb 7, 2006 | 06:12 PM
max929's Avatar
Explain it alittle better, Do you mean that the bolts that hold your calipers are stuck???
Old Feb 7, 2006 | 06:15 PM
vsamoylov
so they are free but they wont come off?
Old Feb 7, 2006 | 06:16 PM
LA02MAX's Avatar
did you mean stripped, maybe?
Old Feb 7, 2006 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
Loose, gone, stuck
Old Feb 7, 2006 | 06:19 PM
MetaOrbit's Avatar
Got Projectors?
Used properly, english is a powerful and descriptive language.
Old Feb 7, 2006 | 06:20 PM
SuperStasiu's Avatar
Maybe he means he took the bolts out but the caliper wont come off. Take a big azz screwdriver jam it between the rotor and caliper and ply, dont know if this helps?
Ahh can you explain wtf is going more clearly???
Old Feb 7, 2006 | 06:24 PM
NmexMAX's Avatar
dot dot dot ...
but......It seldomly ever happens here....
Old Feb 7, 2006 | 06:28 PM
MetaOrbit's Avatar
Got Projectors?
QFT
10 char.
Sorry for the bad explination. Ok Im trying to take off my caliper because i wanna replace my rotos. you guys know the two bolts the hold the caliper in place over the rotor. These are free. I try to unscrew them but they will not unscrew from their current position. What in you opinion needs to be done?? I tryed to pry out the bolts while unbolting them at the same time but no good. Has anyone had experience with this mess???
Old Feb 7, 2006 | 06:36 PM
NmexMAX's Avatar
dot dot dot ...
What does free mean in your opinion?
Old Feb 7, 2006 | 06:38 PM
max929's Avatar
Ok, So the bolts are turning but not backing out, Correct?
Old Feb 7, 2006 | 06:40 PM
vsamoylov
post 13 and we are still trying to figure out what exactly he is asking. nice progress.
Old Feb 7, 2006 | 06:41 PM
yes
Old Feb 7, 2006 | 06:45 PM
NmexMAX's Avatar
dot dot dot ...
The smaller or larger bolts?
max929's Avatar
First suggestion,
If you have a Punch and can see the other end of the bolt, "lightly" tap it out. Don't use to much force so that you don't damage the caliper. After a couple of taps, try to unscrew it again.
Old Feb 7, 2006 | 07:13 PM
Hoooper
First suggestion,
haha, some new threads in the mount are gonna look cool. as for the english lesson, saying "seldomly ever happens here" = bad english. we like to say "seldom happens here".
so it spins free and doesnt back out, this is the bolt from the mount to the caliper...try pulling the caliper away from the bolt ie: <caliper---bolt> while unscrewing it. it sounds like the bolt is in past the threads and just needs to be pulled back enough for the threads to catch.
Old Feb 7, 2006 | 07:50 PM
irish44j's Avatar
retired moderator
could be worse....I look down at my wheel the other day (front right) and see that the upper caliper mounting bolt (smaller one) is COMPLETELY MISSING. GONE. Caliper had fallen down about 1" but not enough to hit the inside of the wheel. No idea how long it's been like that
thankfully, Joel (puppetmaster) had an extra bolt about a mile away
Old Feb 7, 2006 | 07:51 PM
irish44j's Avatar
retired moderator
sounds like it was cross-threaded and somebody forced it on there with an impact and stripped the whole thing.
what you should do is use a vise-grip wrench, lock it on the top of the bolt, and turn and pull at the same time.
Old Feb 7, 2006 | 08:03 PM
NmexMAX's Avatar
dot dot dot ...
It doesn't even look right ...
Scary that people do this to other peoples brakes.
Old Feb 7, 2006 | 08:08 PM
Hoooper
scary that people are stupid enough to do that to brakes...period. then, if it does happen, just leave it.
Old Feb 8, 2006 | 07:53 AM
vsamoylov
its scary how much stupid stuff techs do these days. al lthe yacare about is gettign the car in and getting it out the fastest way possible and quality doesnt even exist.
Old Feb 8, 2006 | 09:20 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
use vicegrip and pull them out........
Old Feb 8, 2006 | 09:24 AM
qballjr13's Avatar
Caliper Bolts
It sounds like your having problems with the smaller bolts, but ALL four bolts, including the two larger ones need to be removed to get the caliper off.
Old Feb 8, 2006 | 09:31 AM
maxS
how come / since when all 4???
Old Feb 8, 2006 | 09:43 AM
qballjr13's Avatar
Well if he wants to replace the rotor the second set has to come off to remove that secondary frame. I assume he is going to replace the rotor if hes doing any brake work. Maybe a bad assumption?
Old Feb 8, 2006 | 09:46 AM
vsamoylov
well we dont know if he is replacing the rotor. we still dont know what he is trying to replace
Old Feb 8, 2006 | 10:09 AM
qballjr13's Avatar
I understand. We still dont even know what the issue was the first two bolts! LOL
Old Feb 8, 2006 | 02:09 PM
I am replacing the rotors and pads why else would i have checked right??
Old Feb 8, 2006 | 04:10 PM
Hoooper
cause you dont replace the rotors everytime you replace the pads...
PS: did you get it or not?
Old Feb 8, 2006 | 04:23 PM
WasatchY2KMax's Avatar
maybe he's swapping in a Dana 44 or something... lifting it... installing lockers... Oh Sh^t! Wrong message board... thought I was on www.therangerstation.com lol
Old Feb 8, 2006 | 04:26 PM
Hoooper
glad you decided to be useless on this thread and not an extinct one.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
