drop resistor mod for tranny?
how is it done. i look in the faqs and the how-tos and the stickies and could not find how to do it. and is it only for the track or can i drive it daily like that?? thanks in advance for any help.
If you do this mod make sure you ad a Transmission cooler. After doing it if it triggers you CEL you should get new transmission shift solonoids because your line pressure soloniod is more than likely wore out. I did this mod on my car and wired it to a switch in side so I can use the mod when I want. When using it it would trigger my CEL. After changing the soloniods the CEL doesn't come on any more when using it.
where is the solonoid located?
On the valve body just under the pan. They are about $200. shipped, then you have to get a pan gasket and trans fluid to change the trans oil. It is worth it. There are 5 soloniods. 1 for ( 4 )for each gear and 1 for the oil pressure (line pressure). I found it worth every penny. I did mine at 100,861 miles, and it still runs like new.
Yes, you will have to remove the valvebody to put them on. Copy and paste these, they should help.
http://www.vqpower.com/v2/modules.ph...howpage&pid=60 https://maxima.org/shoptalk/sub_m...er/index.shtml
maxima-junky
Oct 7, 2015 06:13 PM
ballerchris510
Sep 23, 2015 08:46 PM
and you have proof of this?
