putting in y/b pipe... replace 02 sensors?
Im probably going to get my budget y/b pipe within the next month so i was wondering if i should change the o2 sensors. Car has 130k miles on it and although i do have maintenance records for it, they say nothing about getting any o2 sensors replaced.
You don't have to get any O2 sensors when changing the Y-pipe. It is encouraged since you already have the pipe out, but not required. I didn't changed my O2 sensors when replacing the y-pipe and they still in great working condition. But if you have the extra money why not.
well im lucky budget is like a 20 min drive from my house so i guess ill have them stick new o2 sensors in there.
IIRC theres 2 of them in the ypipe right?
And also, where can you buy these from and is any brand ok?
O2 sensors aren't cheap. (especially OEM ones!)
I wouldn't replace them unless you have a CEL. They really aren't that hard to replace, you can get a tool from Autozone that will easily get them loose.
Originally Posted by tikiboom
holy crap you werent kidding
cheapest i found on oxygensensors.com was $63
damn
damn
You'll blow a hole in ur wallet if you do...had some dude put ma Y in and da guy stripped them...prolly cuz he didn't use PBlaster before he took them off...anyways, they're not cheap like u saw so be careful...
If it is the downstream sensor that is throwing the code it is not imperative to replace it since its primary function is a backup incase of an upstream sensor malfunction. However, it is nice to not have the check engine light on 24/7.
mrc00l88
Jan 25, 2024 01:14 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
