Stripped a screw when trying to get the bose head unit out
What should I do? I broke 2 flat-head screwdrivers trying to do it that way, and I stripped the damn thing after using like a PERFECT philips, its just so damn tight...
Should I drill through the middle of it ??? I don't care if the end of the screw is stuck in the bose unit, I'm replacing it so it doesn't really concern me, any ideas?
Thanks!
Josh
Thanks!
Josh
Now you need a screw extractor. Available at Home Depot.
Don't try to take these screws out with the radio in the car. Please the radio and bracket on a bench, screws up. With a new Philips screw driver, tap the driver head with a hammer as you twist.
yea i had trouble with those same screws, i hear that if u actually turn it the other way, tightening it, then try to unscrew that may work. Perhapps hitting the phillips with a hammer, what i used was a tool that uses the downward force from a hammer struck on the top of the screwdriver to actually twist the screw just a tiny bit in order to break it lose, hard to explain, its probly a screw extractor or whatever the last post said.
also, if you still want to take out the remaining screws, try a power tool and a snug fitting screw bit, push down with all your weight and zoom zoom away.
Originally Posted by kbmaxima
+1 to the tightening first thing.
P.S. i hope that you sprayed it with wd-40 or pb blaster first....
I had the same problem. The screws are pretty soft and strip quite easy. The best thing to do is just as you mentioned. Drill through the center of it. If you hit it dead center it shouldn't even touch the Bose deck (good for resale value on ebay). Have fun.
+1 for the tool called an impact driver. The other guy called it a screw extractor. Definitely remove the whole bracket, then work with the screw on the bench.
You'll find yourself using this impact driver tool again and again and saving time - so don't be scared off by the fact it's a $20 tool set.
I used a Power Drill to get those out. Worked perfect. Hand Screwdriver wouldnt have worked with leaning it inside my car. Cant get enough force onto the screw. Those mothers are TIGHT !!!
-matt
-matt
have a friend hold the trim and the radio, place a GOOD philips screwdriver on it, put all your body weight on the screwdriver and turn. Sounds stupid, but I got all of mine out no problem. If the screwdriver can't go anywhere, then it will bite properly.
Originally Posted by PAREDLINE
I would drill it out. It's not as big of a problem as when i stripped the bolt holding the water pump. That was one of the worst days of my car repair career.
That was fun.
Those screws are Fort Knox. My friend and I placed towels on the floor, put the whole thing on its side (radio, climate control, and storage drawer), put on rubber high-grip gloves and put all our weight over the screws and turned. Not fun.
-matt
