Launnching with a boosted car. Techniques?
Old Feb 16, 2006 | 07:52 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
Hey you guys that are boosted and that have been to the track and pulled good 60' times how do you launch your car? Need some help to improve my horrid 60' (changed motor mounts that was one big problem) but ill take any advice on how to launch a boosted max turbo specific because i would think launching a supercharged one is a bit different.
Old Feb 16, 2006 | 09:22 AM
Nealoc187's Avatar
SLOW
You have to be on slicks or at least DRs, there is no other option. 60' doesn't tell the whole story with this much power. I can pull a 2.2 (average) 60' time and then floor it when I hit second gear and spin past half track.
Old Feb 16, 2006 | 09:49 AM
I30tMikeD's Avatar
It only took a few times at the track to realize there is absolutely no point in running street tires
Old Feb 16, 2006 | 09:56 AM
C MAX's Avatar
lol 14 seconds street tires 12.9 seconds drag radials. no traction what so ever like riding on ice with street tires. i let it rev till about 2,000 rpm launch mid peddle then hammer it by second gear.
Old Feb 16, 2006 | 10:19 AM
but see your supercharged i think tis a little diff to launch turboed ones, and i need to get some dr or slicks, from what i remember when mardi got his 11.5 he lauched at 7k rpm i believe.
Old Feb 16, 2006 | 10:43 AM
JClaw's Avatar
Whatever you do, launch real low.
Old Feb 16, 2006 | 10:48 AM
95maxrider's Avatar
Lightly modded
How are the mounts working out for ya?
Old Feb 16, 2006 | 10:49 AM
C MAX's Avatar
7k are you serious? where would he go, lol.
Old Feb 16, 2006 | 10:56 AM
i dont know but he had slick so im assuming he could grip, but in the article it said he launched at 7k
Old Feb 16, 2006 | 11:02 AM
Here is the part of the article.
In the Spring of 2004 Mardigras felt that he had exhausted the potential of the Supercharger and wanted more power, a faster car and better quarter mile times. At the time, turbo-charging the Maxima showed the potential of doing just what he had in mind. Over the summer and winter months the Supercharger install was dismantled and the car was retrofitted with a T4, 61-trim Turbo. On March 6th Mardisgras was able to put the new install to the test and try to break his previous record. He threw the M&H slicks on the car, turned the boost up to 16.5lbs, armed his 35 shot of nitrous, revved the car close to 7000 rpm and when the light turned green he let-er rip!! Not only did he beat his previous record, he shattered it! He crossed the finish line in 11.5 seconds at 121mph!!! What makes this even more special is that all of this is done with a bone stock Nissan VQ30 engine!!!.
Old Feb 16, 2006 | 11:09 AM
DandyMax's Avatar
3.5 in the works
If you can get traction and if your drivetrain can handle it wouldn't you want to lauch higher so you're in the best part of your power band (ie -already into full boost)?
That's the nice thing about a 2-step limiter, you can sit there at the line and build boost before you launch (well that and being more consistent, less pedal finesse required).
Old Feb 16, 2006 | 12:01 PM
C MAX's Avatar
ouch lol, shoot when i launch at 2K i twist up my radiator support. god bless him lol.
Old Feb 16, 2006 | 09:57 PM
hlh0501's Avatar
Ideally I want it right at the border of traction. For me, this meant launching (doesn't mean dumping the clutch!) around 5000-6500rpm. A quick feather holding power@wheels vs traction balanced, ending with full engagement around 5000rpm. *Remember turbos spool accordingly to load -- simply being at 6000rpm does not mean you are making any boost or significant power
If I had to choose - I would always rather spin more than launching at 2000rpm and bogging. Spinning is controllable, but once you are bogged/lagged you can't help that (other than clutching again etc, which turns into a mess)
I'm sure you get the idea now about tires, you need slicks if you are trying to plant serious power.
Old Feb 16, 2006 | 10:03 PM
hlh0501's Avatar
One other thing to consider when launching a manual... drivetrain shock.
If you have lined out traction to the point that you can come off the line hard, you may want to start slipping the clutch a little at the tree while on the brake to load the drivetrain. This way when you launch you are just finishing the motion, rather than delivering a shock/blow to the transmission+axles
Old Feb 17, 2006 | 02:21 AM
jcy98maxse's Avatar
Turbo is too much fun!
This may sound like a noobish question but I have no experience with slicks or DR's. I know with slicks you would do a burn out in the burn out box to heat them up but does that need to be done also with DR's?
Old Feb 17, 2006 | 04:46 AM
Blu's Avatar
Blu
the tits
yes if you want optimal performance...
Old Feb 20, 2006 | 06:27 AM
95turbo gxe's Avatar
street tires blow 60ft 2.4 and have a 6.7 330ft and finish with a 14.0 in the 1/4 go d/r or even better slicks but when you do grip whoops their goes the drive train!
Old Feb 20, 2006 | 07:03 AM
Brad92SE's Avatar
I actually do a burn out with my street tires. I've only recently started doing that, and have been able to get better traction after heating them. I have Kumho MX's by the way.
Old Feb 20, 2006 | 07:57 AM
JClaw's Avatar
Doing a burnout on street tires goes against common sense because it makes them slicker and actually should make them more prone to spinning, but I have to admit that I am at a loss on how to explain that my best 60' on street tires with no burnout is 2.12, and the best 60' on the same tires with a burnout is 2.02.
Old Feb 21, 2006 | 12:23 PM
MardiGrasMax's Avatar
cleaning the crud and gritt off them helps the traction compound work better to stick the track to them
Old Feb 22, 2006 | 08:12 AM
margi can you describe in detal how you lauched for your 11.4 run with the 3.0? Because that article really doesnt say much.
Old Feb 22, 2006 | 09:56 AM
Slicks at ~12.5psi. Pull into the water box lock the e-brake and spin for just a second to get the slicks clean and wet. Pull forward a foot, lock the e-brake and spin up first, shift into second and hold at revlimit until I see smoke start comming up for a few seconds. Release the e-brake and shoot forward as im letting off the gas perhaps 10 feet or so to see how they feel and grip. Begin to pull up to the line. Talk to myself telling myself to calm down and drive my race! Stage first light. Purge the juice, arm the system. Stage the second light. Press my helmet back against the headrest. Rev to 7k and hold. Wait for the last yellow or the three yellow on a pro tree and quicky pull my foot up off the clutch and I floor the gas. Normal fast shift into second at 7k...
Old Feb 22, 2006 | 10:20 AM
C MAX's Avatar
damn 7000 rpm lol, i heard it all, and you better hold that head back or it will snap off lol.
Old Feb 22, 2006 | 11:24 AM
thanks mardi very nice description i liked it a lot lol
Old Feb 22, 2006 | 05:39 PM
mad-max98's Avatar
and i hope your axles survive that like his did lol
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
