3.5 turbo dyno
Old Feb 17, 2006 | 08:02 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
3.5 turbo dyno
Well finally got it dynoed 2 weeks ago. It made 354whp@5650/329tq@5500
I was running 8psi and was getting boost spikes over 5700 and MAF was reading 5.11 @5500.
Old Feb 17, 2006 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
Graph please
Old Feb 17, 2006 | 08:06 AM
Jeff92se's Avatar
I'm needing a caw
Damn! Nice numbers. I want pics!
Old Feb 17, 2006 | 08:23 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
i took a ride in that thing when i was at tilleys shop and god damn it fu$$ing pulls hard.....really impressive setup. Also guys if you need anything done to your cars ask this man right here to do it. He is very very good with maximas and has very good pricing on everything he does. Im definatelly making him my maxima mechanic even if he is 100 miles away. Great guy very pleasant, took me to a bar/lunch place that had the best beer battered fries ive ever tasted, and the bbq wings were amazing. Tilley im coming up this tues most likely to get my motor mounts intalled.!!!
ps. by the way those numbers are on a jwt ecu.
Old Feb 17, 2006 | 08:48 AM
TILLEYS99's Avatar
Old Feb 17, 2006 | 08:53 AM
tilley post a bigger picture cant see **** in this one.
Old Feb 17, 2006 | 09:13 AM
Ghase's Avatar
Decent numbers Tilley, but what turbo did you use????
Old Feb 17, 2006 | 09:16 AM
TILLEYS99's Avatar
To4R 67trim/stage 5 T3 exhaust housing.
Old Feb 17, 2006 | 09:19 AM
*FleXIMA*'s Avatar
YOOO TILLEY MY MAIN man.. he is the man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! KEEP DOING WHAT your doing!! sorry for the caps lol
Old Feb 17, 2006 | 09:27 AM
I30tMikeD's Avatar
what were you spiking to? Graph doesn't took to have a boost spike in it?
JWT ECU?
Old Feb 17, 2006 | 09:33 AM
I30tMikeD's Avatar
You cerainly shouldn't be maxing out your MAF @ 350whp....that is a sign of the JWT not letting you make near the power you should be with the amount of air comming in the motor
Old Feb 17, 2006 | 09:37 AM
TILLEYS99's Avatar
I was spiking around 10-12 psi for some reason but as soon as it would spike the MAF was done. I think i have my spike figured out and im gonna put a different 2k2IM(ported) on. I also just got my Ford lightning 90mm MAF yesterday so we are gonna test that out.
Old Feb 17, 2006 | 09:39 AM
TILLEYS99's Avatar
timing was only hitting around 10 up top but when the MAF maxed out it hit 16
Old Feb 17, 2006 | 09:48 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Corvettes oh yes, those fries....oh those fries!
oh and nice numbers Tilley!!!
Old Feb 17, 2006 | 10:13 AM
i think we should get a meet going just to hang around tilleys shop all day and go to corvettes for fries and wings.
Old Feb 17, 2006 | 10:21 AM
HarrisH's Avatar
I dream of those fries and the cheesesteak every night.
Tatanko's Avatar
Bacon Lover
I'd drive down just for that
Old Feb 17, 2006 | 10:47 AM
TILLEYS99's Avatar
Once im moved in my new place we can have a maxima meet here if anyones down.
Old Feb 17, 2006 | 10:48 AM
Tatanko's Avatar
Bacon Lover
Once it's warmer...which shouldn't be too long from now, judging by the weather as of late.
Old Feb 17, 2006 | 11:15 AM
I30tMikeD's Avatar
Seems to be the standard for JWT....10deg
Old Feb 17, 2006 | 11:31 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Mike and Tilley, you guys mind me posting your dynos vs. each other?
Old Feb 17, 2006 | 11:41 AM
TILLEYS99's Avatar
I dont mind
Old Feb 17, 2006 | 11:52 AM
IceY2K1's Avatar
Tilley JWT(Blue) vs. Mike STOCK(Red)
Tilley JWT(Blue) vs. Mike JWT(Red)
Old Feb 17, 2006 | 11:54 AM
Nealoc187's Avatar
SLOW
Can you make the pics bigger they are pretty hard to see and read the numbers and letters
Old Feb 17, 2006 | 11:56 AM
IceY2K1's Avatar
Look at the TORQUE difference on the first graph, by 4000rpm...Mike's got 350wtq vs. Tilleys' 241wtq..
IceY2K1's Avatar
Sorry...Cardomain is shrinking them....
FIRST graph Mikes hp/tq are on top, while on the SECOND graph Tilleys' hp/tq is on top, if that helps.
Old Feb 17, 2006 | 11:59 AM
1FSTMAX's Avatar
can you try photobucket.com ???...
Old Feb 17, 2006 | 12:00 PM
TILLEYS99's Avatar
I think you used one of the messed up runs. I know one had horrible tq for some reason.
Old Feb 17, 2006 | 12:02 PM
Matt93SE's Avatar
STFU n00b!
then host 'em somewhere else.
if you need a host, email the originals to me and I'll stick them on my server.
Old Feb 17, 2006 | 12:05 PM
i got a photobucket account if u need it pm me and ill give u info.
Old Feb 17, 2006 | 12:10 PM
IceY2K1's Avatar
Look now.........
Old Feb 17, 2006 | 12:14 PM
noice!!!!!!
IceY2K1's Avatar
Your best torque run by 4000rpm was Run#1 with 272.54wtq vs. Mikes' 350.38wtq, which is better. However, your AFR was 15.18 and each run kept getting lower as you lowered the AFR to a safer range.
Old Feb 17, 2006 | 01:48 PM
Fred Allen Burge's Avatar
I'd suggest a larger exhaust housing, and a serious intake manifold if you're chasing bigger numbers. Your dropping in power in the last 1000 RPM, and by a lot.
allen
Old Feb 17, 2006 | 02:44 PM
JClaw's Avatar
Timing seems to really make a HUGE difference in power. The 3.5 can run ALOT more than 10 degrees @ WOT.
Old Feb 17, 2006 | 05:18 PM
I30tMikeD's Avatar
allen
I would guess the large drop is mainly due to the leaning out the last 1K rpms
The 3.5 should be making much more torque than me. I am sure it's all in the JWT ECU.
Old Feb 18, 2006 | 04:19 AM
TILLEYS99's Avatar
allen
Thats one reason i hate the 2k2 IM it sucks over 5500 or so......
Last night i swaped my wastegate and i still get boost spike over 5500 I checked the pipe for the wastegate to see if it is restricted and it seems too be good, i even thought maybe the single vac/boost source wasnt good enough so i tried another.....any ideas????
Old Feb 18, 2006 | 01:19 PM
GBAUER's Avatar
fab up a spacer below the IM. Adds 35 WHP stock to the Z's. Our IM sits too low and blocks/slows air at higher flows. The spacer should allow for greater velocity and flow at higher boost/rpm. I'm probably not explaining it well. Talk to Corey.
Old Feb 18, 2006 | 03:37 PM
Blu's Avatar
Blu
the tits
Time to ditch the POS JWT ECU and instantly gain 50whp. No way Mikes 3.0 should have more torque than the 3.5 at any rpm range, same for the HP.
Old Feb 18, 2006 | 03:40 PM
chris'smax's Avatar
edit edit edit
