Which relay for hyperblinking LED turn signals?
Who has a link to the right relay for 4th Gen. turn signals that have been replaced by LED's? I'm considering this as an alternative to load resistors to avoid splicing into any wiring.
Originally Posted by njmaxseltd
I don't think there is such a relay. Load resistors might be your only option.
http://www.superbrightleds.com/cgi-b...gi?product=CAR
LED bulb flasher unit
Originally Posted by n3985
all you have to do 2 make your light blink fast is connect the clearence green wire to he green wire of the blinker.......thas it and i blinks fast...i have the link but i'm not at home i'll get it 4 u later
Originally Posted by White Shadow
I don't want them to blink fast, I want them to blink normal. LED's as turn signals don't work unless you use load resistors or that relay. Without it, they won't work at all.
Originally Posted by MDeezy
Wrong, my led tails have been working just fine for the past 7months, I need to get a load resistor so they can blink at a normal speed, but the definately work.
Well mine don't. They hyperblink on the dashboard indicator and do absolutely nothing outside the car. Strange...
i made custom ones for my friend's car and i just used a 6 ohm 50 watt resistor and connected it to the wires connecting to the bulb. i made it plug and play and they work great. it is cheapest just buying 2 3 ohm 50 watt resistors in series and have one end connecting to the positive wire, the other to the negative wire. do this by buying a splice tap, which is the fastest easiest way to fix your problem. eBay and other sellers sell the load resistors forl ike 7 bucks a pop, just go to your local electrical shop ( not radio shack ) and they'll sell you 4 resistors for 3 dollars. which is a lot cheaper than what other sellers sell them for. if you have any more questions about how to cure the hyper blink thing i can help.
Came up with a pretty simple compromise solution. All my lighting is now LED's except for the turn signals. I just got another pair of chrome coated amber 1156 bulbs like the ones that came with my CE red/clear tails for about 6 bucks. I wonder why they didn't include bulbs with the clear bumper lights as well? They won't have the ugly "fried egg" look of the orange bulb in the clear lens anymore which is what I was primarily after. The ones in the tail lights are pretty much invisible because they blend in perfectly with the reflector. Now all I have to do is find some regular 9007 headlight bulbs that look white and not yellow or blue...
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
