Sponsored by:
Sponsored by: CARiD
nismo adjustable fuel pressure regulator
Old Mar 1, 2006 | 07:46 PM
t6378tp's Avatar
Turbo 3.5
hey has anyone installed a adjustable fuel pressure regulator on there ride, I was looking to add a 50 shot dry nitrous kit and thought adding a nismo reguator might be handy. is this something worth looking into or a waste of time and money for the mods I currently have and looking into
car: 96 se
mods: y pipe, flow master muffler, injen cai, drop mod
I am kindy new to this and info will help thanks
Old Mar 1, 2006 | 08:39 PM
NmexMAX's Avatar
dot dot dot ...
Then why are you posting in this forum?
car: 96 se
With those mods, you should be fine, but wont know until you see your a/f. ... And adjust accordingly, and if you're running out of FP up top like some cars do, then you either need a Fp, or AFPR.... But with your current breathing mods highlighted in red, you wont need it.
Old Mar 2, 2006 | 02:54 PM
nfo184's Avatar
without a safc2 or afc controller the fuel pressure regulators dont do anything for are cars right??? since our fuel injectors cant really pump out any more??? or if i put 300zx 330cc injectors in...will it even work? or will I get a CEL light on and the same flow since my ecu calibrates the fuel map????
Old Mar 3, 2006 | 06:48 AM
NmexMAX's Avatar
dot dot dot ...
Cripes..... you have no knowledge on this subject whatsoever do you?
Old Mar 3, 2006 | 08:06 AM
tavarish's Avatar
fwd gone rwd cr00
what exactly is knowledge?
Old Mar 4, 2006 | 06:55 PM
nfo184's Avatar
not really thats why i'm asking u guys....if i just put 300zx injectors in will i notice a gain? or do i need a hi pressure walboro fuel pump too? or can i just get a fuel pressure regulator and up it up a lil more??? any ideas ...thanks i need help with this lol i'm not a mechanic
Old Mar 5, 2006 | 07:00 AM
doc2278's Avatar
Doctor D I presume???
I think you need to think about where you want to go with this mod of fpr (fuel pressure regulator) and 330cc injectors, because if you do this mod set up, you dumping more fuel through the lines really isn't going to give you much gain unless you are getting forced induction. In that case you would need a larger fuel pump, boost controller, safc2 controller among other costly equipment. if this is your goal then you might want to refer to the supercharged/turbocharged forum.
but if that isn't your goal you are better off advancing your timing and getting an a/f controller (dyno tune first to see if you need the a/f controller) for this is what will give you a more efficient gain especially if you want to stay N/A (naturally aspirated). I don't jack about a nitrous set-up and whats required there,...check the nitrous forum, cant hurt to weigh your options right? i hope this helps you. good luck newbie
Old Mar 6, 2006 | 06:26 AM
nfo184's Avatar
thanks man ....lol hey i'm only a newbie to this just cause i never did engine work and posted on this lol thanks tho
Old Mar 6, 2006 | 03:20 PM
doc2278's Avatar
no prob, like I said hope it helps you
Old Mar 7, 2006 | 06:45 PM
t6378tp's Avatar
Turbo 3.5
thanks this helps me also, I just looking into all options
I know that with the bigger filter and cai and y-pipe and exhaust that I am getting more air in and more air out soo I just thought that maybe I would need to get more fuel in to go along with the air
I have a auto and it boggs alittle with the cai in low rpms, it seems like the computer can not compinsate for the extra air fast enough or maybe I am just crazy
Old Mar 7, 2006 | 06:50 PM
NmexMAX's Avatar
dot dot dot ...
You need an a/f graph to verify that thought.
Old Mar 7, 2006 | 06:59 PM
t6378tp's Avatar
Turbo 3.5
I know but there are not alot of dyno shops in my area, I found one about 15mins away when I googled it but they did not have a phone # on the web site, sounds like bad news already but I'll just drive pass 1 day
Old Mar 7, 2006 | 07:24 PM
NmexMAX's Avatar
dot dot dot ...
Then stop getting ahead of yourself and diagnosing a condition that you may not even have.
Don't pass by, stop in and ask details.
Old Mar 7, 2006 | 07:49 PM
nfo184's Avatar
yea thats the best way....run a dyno man...i plan on doing it this spring ....they hook up all ur o2 sensors and find out ur a/f ratio
Old Mar 7, 2006 | 07:51 PM
nfo184's Avatar
ok so i have a cai.......i also had a weapon r short ram hi flow that sounds louder but i can barely tell the difference.....hi flow is better at higher rpms and cai is better for automatics and better in the low end....but i heard with a y pipe ur susposed to only have a hi flow or short ram???? is this true??????
Old Mar 7, 2006 | 08:06 PM
NmexMAX's Avatar
dot dot dot ...
Most if not all shops do NOT do this.
It's actually personal preference meaning you can do whatever you choose.
Old Mar 7, 2006 | 10:47 PM
zander's Avatar
Wow NmexMAX must have been having a good day. Not once did he flame you guys. Consider yourself lucky!
Old Mar 19, 2006 | 08:29 PM
nfo184's Avatar
lol thanks then...cool ....i'll def keep the cai then if it doesnt hurt me
Old Mar 20, 2006 | 05:32 AM
abci30's Avatar
oh noes!!!!1111
http://www.phillydynoworks.com/index_site.htm here is a dyno in philly and here is the phone number 215.238.9850
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
05RLS2
Apr 14, 2016 11:49 AM
leatherneck
Sep 30, 2015 09:16 PM
