!!Antifreeze LEAK!! HELP!
Old Mar 6, 2006 | 05:51 AM
96mAx2fast's Avatar
Whats up guys!?
This morning, I went to auto start my 96 5spd max and it kept shutting off after about 3 seconds. I walked outside and noticed that there was some shiny green liquid on the floor under the car (in front of the oil pan). When I looked under the hood, the antifreeze container looked like it had lost about an inch of liquid. I can't seem to find where it was coming from. I could see the drops falling (at about 1drop per every 5 seconds), but couldn't see where from. What could this be? Any ideas? Trouble shooting suggestions? anything?
I took my wife's car to work and plan on checking it out tonight. I left it on some ramps so that, hopefully, I can see & fix the problem tonight !
Old Mar 6, 2006 | 05:55 AM
clive's Avatar
100% chingon
Probably the radiator. First check the hoses. You'll probably keep it going for a while with one of those leak-repair compounds.
Old Mar 6, 2006 | 06:15 AM
96mAx2fast's Avatar
I cant seem to find the hole. The leak seems to happen between the radiator and the oil pan..If it is alittle crack in a hose, could i just kinda melt it together with a soldering iron and then put that paste thing you are talking about?
Could it be anything major? costly?
Old Mar 6, 2006 | 10:31 AM
BourneJ's Avatar
check the clamps where the hoses go into the radiator.
I found small puddles of antifreeze in my garage & when I lifted the car, both hoses were loose on the radiator.
Old Mar 6, 2006 | 12:07 PM
96mAx2fast's Avatar
I will try that tonight. I went to pep boys and bought alittle bottle of that sealer powder which, according to them, works wonderful. It was like 5 bucks. I will check the hoses first though.
Old Mar 7, 2006 | 04:57 AM
96mAx2fast's Avatar
Update
Alright guys, I checked out the whold car. Believe it or not, I think the antifreeze is someone escaping from the cap. When I pop the hood, there's shiny green liquid all around the cap! I tried to tighten it but it doesnt seem to tighten anymore.. I looked at the hoses and everything seems fine. Where can I get another one of those little caps? Does anyone know how much they go for?
Old Mar 7, 2006 | 05:04 AM
pratch's Avatar
The most I've seen for a custom rad cap was about $15. I'm betting on a $8 price tag for a generic but good one at DAP or AutoZone.
Old Mar 7, 2006 | 08:00 AM
96mAx2fast's Avatar
thats a good price!!! Has anyone ever heard of a bad cap, therfore a leak occurs. The stupidist things happen to me!!!!!!!!!!!!!
Old Mar 7, 2006 | 11:54 AM
Mr Willis's Avatar
same problem
Is that stuff something u just pore into the cooling system or what?
Old Mar 7, 2006 | 12:04 PM
pratch's Avatar
From AutoZone's site:
RADIATOR CAP for a
1995 NISSAN/DATSUN MAXIMA
Item:
CST
PRESSURE RELEASE
Part #:
7913
Price: $8.99
AND
Item:
CST
REGULAR
Part #:
7513
Price:
$6.99
And yes - I've heard of caps losing their seal and causing leaks. However by the time I've noticed them, it's usually a close-to-overheating situation.
Old Mar 7, 2006 | 12:23 PM
Tarzan26's Avatar
RADIATOR CAP for a
Item:
CST
PRESSURE RELEASE
Part #:
7913
Price: $8.99
AND
Item:
CST
REGULAR
Part #:
7513
Price:
$6.99
does your over flow tank get filled quick.. because if it was coming from there it "should" go into over flow?
Old Mar 7, 2006 | 12:50 PM
96mAx2fast's Avatar
Well, my regular antifreeze tank is in the top line. The powder thing that i bought went into the radiator itself. I removed the top when it was cool and just poured it in there.. I dont seem to see anymore leaks with the exception that the i see some fluid around the cap when i pop my hood after its hot..
Old Mar 7, 2006 | 01:39 PM
Mr Willis's Avatar
I must be confused. If it were the cap wouldn't there be a dribble of coolant going all the way down the backup reservoir? Wouldn't it be blatently obvious?
Old Mar 7, 2006 | 02:02 PM
t0p_sh0tta's Avatar
Be careful when replacing the radiator cap. If the rest of your cooling system is pretty worn (soft hoses, lots of corrosion on rad itself), replacing a bad/worn cap may raise the pressure high enough to make something else go.
Old Mar 7, 2006 | 06:24 PM
Mr Willis's Avatar
Buddy that is a very good point!
Old Mar 8, 2006 | 05:38 AM
96mAx2fast's Avatar
fixed
Fortunately, when i took the cap off, cleaned it and put it back, the leak stopped. I guess that sealer powder i put in it worked. It hasnt leaked since. Im thinking there was a minor hole in one of the hoses and the sealant sealed it.. Thanks anyway for all the support guys!!!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 12, 2015 07:06 AM
RWCreative
Sep 21, 2015 11:01 AM
