rear end squat question
Old Mar 7, 2006 | 11:07 AM
aih98max's Avatar
scoobystoned...
when i accellerate hard in my 98 GXE auto maxima, the rear end squats and the front raises up like 2 inches. Are my rear shocks and struts bad? or is this common. i have 2 10 inch subwoofers in the trunk that add weight also, but i didnt think it be that much. Also, sometimes when i park it, the back looks low and the front high, but just sometimes. thanks guys.
Old Mar 7, 2006 | 12:42 PM
Trajiksmax's Avatar
Proud Maxima Owner
Normal with stock struts, this will tend to go away if you use a aftermarket spring/strut combo.
Old Mar 7, 2006 | 02:12 PM
t0p_sh0tta's Avatar
It'll never go completely away. If you upgrade to aftermarket springs, it'll be less noticeable due to thier stiffness. The only way to compensate for the saggy *** would be to pick up a set of coilovers.
edit: It's not normal for the nose to lift 2" under acceleration. Everything out back is probably worn/weak.
Old Mar 7, 2006 | 02:47 PM
dgeesaman's Avatar
Maintenance Monster
It's normal.
Dave
Old Mar 7, 2006 | 06:12 PM
aih98max's Avatar
scoobystoned...
my rear struts and shocks could be worn, i bought the car at 128,000 miles and it now has 133,100 miles (which is low for a maxima). i dunno if they have ever been replaced, when do you normally replace shocks/struts? also, could i buy the shocks and struts from a SE and put those on my GXE because the SE has a better handling suspension?
Old Mar 7, 2006 | 06:13 PM
jman7777's Avatar
i wasn't too sure what this thread was asking by the the title...
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
wingsfan24
Aug 15, 2015 07:35 PM
Bruceharrison
Aug 9, 2015 07:56 AM
