Lug nut stub stripped or something
So i go to rotate my tires today and i found out that one of my front lug nut stud and the lug nut itself are stripped. At first i thought they just cross threaded the nut, so i got another nut and tried to put it in. And it just wouldn't get on. So i'm thinking they cross-threaded my stud instead.
I have an idea of who did it, i rotated my tires last summer and everything was good. I got my tires put on in the fall and nothing else was done reguarding the lugs. And today i found out that its stripped.
Both the lug and the stud. I can problay get another nut easily but what can i do about my stud. I'm bothered because now that i know something is wrong i'm thinking 4 lugs isn't going to hold the tire and its on my front side.
Are they options to repair it or would i need something like a new hub?
i'll rather not drive on 4 lugs knowly. its in the front driver side. So it would be a little more important to get that done with.
Can i rethread them, the stud mainly. I'm just going to dealership to buy a new lug or how ever they sell them.
As long as the other lugs are torqued on properly you'll be fine with 4 lugs.
A replacement stud should cost ~$3 at the dealership. Replacement is very easy, assuming your willing, it goes as follow:
*Loosen lugs dont remove
*Jack up car, secure of jack stands
*Remove studs and remove wheel.
*Take off caliper bolt x2 - (14mm)
*Remove and hang securely caliper
*remove brake pads
*Unbolt Torque member bolts x2 - (19mm)
*Remove TM, and remove rotor (should slide right off).
*Put the car in neurtal. Rotate the bad wheel bearing so that is in the middle of the open part of the rotor splash shield
*Using a large metal hammer, bang with much force on the stud till it comes out.
*put new stud in, and using 7/16th washers (about 7 of them) put them on the stud (where the lug nut would go)
*Put the lug on, and tightned till it seats the new stud in place.
*Remove lug nut
*remove washers
*reverse install.
This may seem overwheelming or a lot but I just listed every single step taken. This should take about 15 - 25mins tops to do.
*remove brake pads
*Remove lug nut
*remove washers
*reverse install.
that sounds very easy enough. Minus the hammering part, cause i know it will be a pain to get out.
I actually wanted to see if i can use a tap and die set to try and rethread that first. Since its a little more easier to try then to hammering.
True, but i have a thing against hammering things. ONLY a last resort.
I torqued my other 4 lug nuts to 80ft-lbs. I was unsure of the spec of them, so i guess and when with 80.
If anything i'll just do the brakes on my car as well seeing as how i have everything dissassembled to take care of this.
lol, that was my situation for almost 2 years....I noticed a long time ago my dad was driving on 4 studs, and told him, but he didnt do anything about it. I figured it wasnt a problem... Then when i got my brakes done, they stripped a stud, and cross threaded another... Needless to say riding on 3 studs sucked.. So i get to Discount, they spend 15 minutes trying to impact the cross threaded one off....It was probably the funniest thing ive seen in a garage.... Either way, Its not a huge labor charge, but it would be more fun to do yourself...
Originally Posted by maximaman10
Just take a hammer and tap out the bad stud and tap in a new one. Then take a lug nut and pull it into place. It is really easy. I have done it in 10 min.
yep did 4 last yr
i already knew how to do brakes. Do brakes on 1 car you can do almost all the others. Only thing is the hammering and re-hammering that i haven't done to a stud yet.
Normally to pull out a stud i just used an impact and 2 bolts. back to back and pull a stud out, same for getting it back in. I'm thinking it would work in this case as well.
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
