transmission cooler
transmission cooler
hey guys,
I will plan to drive my car hard this summer most likely, i'll be attanding some drag races, and i was wondering whats the best thing that i can do for my automatic transmission.....
i thought of tranny coolers, they're not expencive and easy to installl....
did some research on it here on org, but couldnt really find as much info
, if any of you have done it, let me know what you guys think of it?
which one did u get and where? a link would be excellent......so i can order me one too....
thank you
Huso Selimovic
, if any of you have done it, let me know what you guys think of it?which one did u get and where? a link would be excellent......so i can order me one too....
thank you
Huso Selimovic
The Answer to your question. Not as Coslty too..
https://maxima.org/shoptalk/sub_modi...er/index.shtml
but is everything same for 4th and 5th gen.....nothing differ?
and does anyone have one, did they notice any difference?
and yes andrew i'll change my oil to Mobile1
thanks a lot guys
huso
i used that writeup back in the day to install my hayden cooler and a b&m one on blu's old 02. i am certain that almost everything was the same mainly because i do not remember any surprises. when you do change the trans oil, i would recommened dropping the pan. clean up the pan, magnets and check the the screen/filter for any tears and clean it up as well.
I didn't read that whole write-up, but yea it's probably the same. Pretty easy to do.
Go to autozone spend $30-50 on a universal cooler and another 5-10 on some high pressure lines (just to be safe) and nice clamps. The cooler will come with strip ties. Put the cooler on the front side of your radiator, put strip ties thru the fins of the cooler and radiator on all 4 corners of the cooler. Tighten strip ties down. Your cooler is now in place.. Cut your tranny line going to your radiator. Run one of the hoses from the cooler into the radiator side of the line you cut. Run the other hose into the trans side of the line you cut and you done. 45 minutes and $60 tops and your good to go.
The B&M.........
The B&M is what I installed. I also use Mobil 1 Syn ATF. I liked the B&M over the Hayden because it has cold fluid/low pressure bypass built in. Have had no issues for over a year.
Originally Posted by Spin20
Does anyone know if installing this will void the warranty on the tranny? I wanna do this but I still have another 30k worth of warranty
tarun900
19
Dec 20, 2021 06:57 PM
Pied
Sep 26, 2015 03:29 PM
